96 7.3 Problem!!! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 18 (permalink) Old 04-26-2011, 05:13 PM Thread Starter
96 7.3 Problem!!!
Here lately when I go out to start my stroker to head to work I have to cycle threw the glow plugs 3 to 4 times before it will start. While driving the truck will just fall on its face for a second or 2. Sometimes it will do this as soon i start driving and sometimes not for about 15 minutes. Anyone got some ideas?
Thanks
2008 F-250 6.4 CC doc/dpf delete, s&b intake, sct livewire innovative xtreme street
2004 Mustang GT heads/cams/gears
1996 F-250 Strait piped, ts 6 pos. diy intake
brock04gt is offline
post #2 of 18 (permalink) Old 04-26-2011, 05:33 PM
Re: 96 7.3 Problem!!!
Have you started it without the edge on there? How old are the glowplugs? How old is the oil?
02 f250
countryboyrob is offline
post #3 of 18 (permalink) Old 04-26-2011, 06:11 PM
OBS Addict
7.3psd97444's Avatar
By "fall on its face" do you mean loses power and rpm or feels like a restriction?
-Jordan-
97 SCLB 7.3 Handshaker
Valair Clutch, only the best.
TS 6 Position Tyrant Tuning
S&B, MBRP, Isspro, Mag-Hytec, 1.00 A/R Exhaust housing, HPX
Full sound system: Kicker-Kenwood
BILLET BADGES
Dick Cepek DC-2's/Duratracs
On-Board Air
Few cosmetics
PSA # 269
7.3psd97444 is offline
post #4 of 18 (permalink) Old 04-26-2011, 06:59 PM
You're not "cycling" the glow plugs. They stay on for up to two minutes when you first turn the key to RUN. Just leave the key in RUN for 20 seconds or so, then try starting it.
Maybe you think that when the WTS light goes off, the glow plugs go off. It's hard to guess where that myth came from, but for some reason, it's widespread, and it evidently came out of nowhere. But it's myth, in any event.
madpogue is offline
post #5 of 18 (permalink) Old 04-27-2011, 02:06 AM
Boost96's Avatar
When I had the edge evo, in the extreme setting it would never want to start cold esspecially if it was cold outside. I installed new glow plugs and it would fire right up. You might wanna check the glow plug relay if its old too.
Boost96 is offline
post #6 of 18 (permalink) Old 04-27-2011, 09:09 AM Thread Starter
I dont have the edge on anymore I got a ts chip about 4 months ago. The oil has a little less than 4k miles on it and when i say "falls on its face" its like the engine quits for a second and picks back up. The glow plugs are pretty old the relay is only about 2 months old.
post #7 of 18 (permalink) Old 04-27-2011, 01:57 PM
OBS Addict
When you experience the "fall on it's face" do you have the chip turned up or in stock position? Ts tunes or custom tunes?
-Jordan-
BILLET BADGES
On-Board Air
Few cosmetics
PSA # 269
post #8 of 18 (permalink) Old 04-27-2011, 02:14 PM
salprofish's Avatar
These are the same symptoms mine was having, turned out to be the cps.
97 250 EC 4x4
5 speed
6637 Napa Filter
ccv mod
3" diamond eye dp
175cc 80% over Rosewood inj.
Custom tuning by Cale Thompson
4" Rough Country Lift
315-70-17 BFG AT Tires
Rebuilt zf5 at 250000
my new favorite gun:
LAR grizzly 50 BMG big boar
salprofish is offline
post #9 of 18 (permalink) Old 04-27-2011, 03:03 PM
Boost96's Avatar
Yeah, the CPS Is probably the culprit, get one from international if possible, around 25 bucks. if your build date is after 6/96 get the newer part number, international switched parts #'s about that time
Boost96 is offline
post #10 of 18 (permalink) Old 04-27-2011, 03:13 PM
I've expirenced the same symptoms and it was cam sensor combined with a bad uvc gasket. Both easy fixes
psd444 is offline
