no start this morning - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 04-26-2011, 12:46 PM Thread Starter
Clouse2411's Avatar
Send a message via AIM to Clouse2411 Send a message via Yahoo to Clouse2411
Well i went out to jump into my truck and start it this morning. Its about 50 out. Right when I turn the key on I get a check engine light and the wait to start light doesnt come on. I hooked up a superchips to read the code and I get no response. It did this same thing Saturday morning. I hooked a snap on scan tool on it Saturday. Wouldn't read codes. I did a buzz test. All 8 injectors went off. The check engine light turned off and it fired up then.
97 F-350 RC LB.
Farmer's 400/400, Irate T-4 Mount And Regulated Return, Bullseye S475, ARP Main And Headstuds, Valair Double Disc, Intercooled, Short Throw Shifter, 4in Lift, Hood Stack, Black Interior, Autometer Gauges, Scan Gauge, Front And Rear Diff Covers, Dodge Tow Mirrors, 36x15.50x18 ATZs
Clouse2411 is offline
post #2 of 11 (permalink) Old 04-26-2011, 01:07 PM Thread Starter
Clouse2411's Avatar
Re: no start this morning
Also I don't hear the glow plug relay clicking like it usually does.
97 F-350 RC LB.
post #3 of 11 (permalink) Old 04-26-2011, 01:11 PM
Keep er shinny side up!
I'd start by checking fuses.
abbottfarms is offline
post #4 of 11 (permalink) Old 04-26-2011, 02:18 PM
OBS Addict
7.3psd97444's Avatar
And checking the gp relay.
-Jordan-
97 SCLB 7.3 Handshaker
Valair Clutch, only the best.
TS 6 Position Tyrant Tuning
S&B, MBRP, Isspro, Mag-Hytec, 1.00 A/R Exhaust housing, HPX
Full sound system: Kicker-Kenwood
BILLET BADGES
Dick Cepek DC-2's/Duratracs
On-Board Air
Few cosmetics
PSA # 269
7.3psd97444 is offline
post #5 of 11 (permalink) Old 04-26-2011, 04:22 PM
Check maxi-fuse #22 under the hood. If it's blown, DON'T just replace it. Prime suspect is the fuel heater in the fuel bowl; it shorts out and blows this fuse, which also powers the PCM and the GP relay. So if it's shorted, it'll just blow another fuse. Search here for directions on how to unplug the heater (you don't really need it, supposedly). Disconnect it, THEN replace the fuse and try 'er again.
madpogue is offline
post #6 of 11 (permalink) Old 04-26-2011, 04:31 PM Thread Starter
Clouse2411's Avatar
I already don't have a fuel heater cause I deleted the fuel bowl. Also is there a way to test the gp relay?
97 F-350 RC LB.
post #7 of 11 (permalink) Old 04-26-2011, 05:02 PM
OBS Addict
Well when mine went out last time it had melted the rubber boot I had covering one of the posts. And had sent a crack down the whole thing cuz it was plastic POS. If you have a test light with ground wire you could at least check to see its getting power. I'm either not remembering or don't know how to check the relay.
-Jordan-
BILLET BADGES
On-Board Air
Few cosmetics
PSA # 269
post #8 of 11 (permalink) Old 04-26-2011, 06:18 PM
Key off, there should be battery voltage at one of the big terminals, and zero voltage at the other. Key on, there should be something less than "resting" battery voltage (expect it to be about 11 V) at the first of the above big terminals, and a little less at the other. The difference should be no more than about 0.3V. And of course, it should make a nice solid clicking sound.
So after the trick with the scan tool, are you getting the WTS light when you turn the key on (without the Snap-on)?
madpogue is offline
post #9 of 11 (permalink) Old 04-26-2011, 06:51 PM
There is a fuse in the panel inside the cab that powers your scanner port. mine blows all the time. change the fuse then scan codes.
dave96psd is offline
post #10 of 11 (permalink) Old 04-26-2011, 07:47 PM Thread Starter
Clouse2411's Avatar
I drove the truck all normal untill this morning. Wait to start light came on and ran excellant.
97 F-350 RC LB.
