swapping E4OD to zf5 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 17 (permalink) Old 04-26-2011, 05:47 AM Thread Starter
im debating on doing the swap because mines gona be going out soon. does anyone have an idea what is all needed to do the swap. or if will actually work right. just want to get some info on it.
thanks john
black97 is offline
post #2 of 17 (permalink) Old 04-26-2011, 05:45 PM
95powersmoker's Avatar
Re: swapping E4OD to zf5
Best thing you can do is have a donor truck sitting next to yours... That way all the parts are there.
James
2000 F350 CCLB 4x4 auto, 250/200's from PIS, No Limit tunes, Isspro gauges, 4" exhaust and intake.
95powersmoker is offline
post #3 of 17 (permalink) Old 04-26-2011, 05:51 PM
Early bird gets the worm
95dieselsmoke's Avatar
I did the swap a while back. Had a complete donor truck. Parts needed off the top of my head... tranny, clutch/flywheel, front driveline, rear driveline, zf5 PCM, ZF5 crossmember, zf5 wiring harness, pedal assembly, shifter/boot, slave/master cylinder I'm sure there is more that I cant remember ATM.
95 F250
Dana 60 swap
9" lift/40x13.5x20 ProComps
ZF5 swap/short throw/SouthBend CON OFE
Rosewood stage I's
TW live tuned
SD innercooler
AFE CAI
autometer pyro,boost
6" black miters
95dieselsmoke is offline
post #4 of 17 (permalink) Old 04-26-2011, 06:09 PM
OBS Addict
7.3psd97444's Avatar
^ what they said. Gonna be a job; having a donor truck will make all the difference.
-Jordan-
97 SCLB 7.3 Handshaker
Valair Clutch, only the best.
TS 6 Position Tyrant Tuning
S&B, MBRP, Isspro, Mag-Hytec, 1.00 A/R Exhaust housing, HPX
Full sound system: Kicker-Kenwood
BILLET BADGES
Dick Cepek DC-2's/Duratracs
On-Board Air
Few cosmetics
PSA # 269
7.3psd97444 is offline
post #5 of 17 (permalink) Old 04-27-2011, 02:34 AM Thread Starter
U just mean driveshafts as far as drive line goes
black97 is offline
post #6 of 17 (permalink) Old 04-27-2011, 06:54 AM
Yes, you need a longer front and a shorter rear due to the transmission being different lengths than each other. Unless its a 2wd then you only have to deal with the rear.
95 F250
Dana 60 swap
Rosewood stage I's
TW live tuned
SD innercooler
AFE CAI
6" black miters
post #7 of 17 (permalink) Old 04-27-2011, 06:58 AM
urbanwheeler's Avatar
dont forget steering column cover and gear selector block off in the gauge cluster.
'96 f-250, auto, shackle flip, solid axle, rsk, high/crossover steering, 3.73's, true trac's front and rear, trac bars, gt4202, 7.3 ic, idm mod, ccv mod, A1000, 4-line DIY Gen3, dual ipr's, casserly 350/200's, arp studs, 910's, pushrods, elec. fan, 2-stage nitrous, fluidampr.
[SIGPIC][/SIGPIC]
urbanwheeler is offline
post #8 of 17 (permalink) Old 04-27-2011, 07:02 AM
Good catch. Those too to finish the job off.
95 F250
Dana 60 swap
Rosewood stage I's
TW live tuned
SD innercooler
AFE CAI
6" black miters
post #9 of 17 (permalink) Old 04-27-2011, 07:06 AM
swamp_ratt's Avatar
have almost everything you need! trans, t-case, cross member, harness, clutch, flywheel, front driveshaft and can get you the pedals, column and floor pan for next to nothing. pm me if interested. if your truck is cclb i have a rear driveshaft for ya too!
1995 F350 CCLB DT360/Allison
1997 F350 RCLB 460/E40D
2001 Jetta TDI 5spd (51mpg work beater)
1995 F350 CCLB 2.5 tons/57s Front, 53s Rear
swamp_ratt is offline
post #10 of 17 (permalink) Old 04-27-2011, 04:15 PM
I just did this swap it is the best thing that I have done with this truck I had a donor truck that I took everything I needed out of none of it was hard everything bolted right in place only took us 12 hours from the time we drove it in until we drove it out. I just got the rearend gears finished swapping out for 3:55's the truck drives so much nicer now it rolls only thing left is the intercooler and tunes from DP tuner. Good luck with your project if you do it.
briggs60 is offline
