Cyl. Head oil drain - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 04-25-2011, 11:51 PM Thread Starter
Cyl. Head oil drain
I Have a 96 f250 obs and I'm replacing cyl. 1 injector...I know I have to drain the oil from the head but when i took the drain plug for cyl 1 and cyl 3 no oil came out only a couple drops....I took the rear one out for cyl 5 and 7 and about a half a cup came out...is this normal.
JVig2121 is offline
post #2 of 2 (permalink) Old 04-26-2011, 04:37 AM
OEM Moderator
Tom S's Avatar
Re: Cyl. Head oil drain
Yes, those are not really drain ports though. You will still need to either suck the oil out of that cylinder or gently remove if with the glowplug out though.
Tom S is offline
