Questions - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 24 (permalink) Old 04-25-2011, 09:37 PM Thread Starter
DAMN THATS HOT!
97strokeonit's Avatar
Questions
I have several questions that have been bothering me for a while and rather than Make multiple threads I figured I would save space and just make one.
1. What are the highest tranny temps I should see with my BTS? the other day after about an hour of Highway time at 75mph it saw almost 250.
2. Why is my truck rough starting on wet days and when I park on a hill head first on the high side? is it possible for some sort of fuel drainage scenerio? My fuel bowl is leaking as well from the little sensor comming out of the side with the wire comming from it on the drivers side looking at the bowl. I had to sip tie it in tight to keep it from leaking.
3. The other day while driving my truck did this really weird buck almost like it just completly stoped for a complete second and jerked. The best way to describe it would be like the shifting mechanisms on drag motercycles where they stall the engine really quickly in order to shift. It didnt drive funny or shift weird or loose power it just jolted all of a sudden and almost like died for a split second.
"The question is not how far. The question is, do you possess the constitution, the depth of faith, to go as far is as needed?"
I like my trucks like I like my women... Fast and Clean.
97strokeonit is offline
post #2 of 24 (permalink) Old 04-25-2011, 10:44 PM
Re: Questions
You have a major problem with those temp's, better check for flow. Do you have a trans cooler?
email:
Website:
OBSWIZ is offline
post #3 of 24 (permalink) Old 04-25-2011, 10:46 PM Thread Starter
DAMN THATS HOT!
Re: Questions
Stock trans cooler. I flushed the sytem when i installed the new trans.
post #4 of 24 (permalink) Old 04-26-2011, 06:31 PM Thread Starter
DAMN THATS HOT!
Re: Questions
Bump
post #5 of 24 (permalink) Old 04-26-2011, 10:19 PM
Built not Bought
1990 Scorpion's Avatar
Re: Questions
If your transmission is getting up to 250 you have something wrong and are causing damage to your transmission.
1996 7.3L Powerstroke
T6 Chip with Tony Wildman Tunes
Autometer Cobalt Gauges
3 inch DP, 5 inch Straight Pipe
S&B Intake
Billet Torque Converter, Triple Kevlar Clutches, Transgo Shift Kit.
1990 Scorpion is offline
post #6 of 24 (permalink) Old 04-26-2011, 10:29 PM
STILL LEARNING
Bradbilt's Avatar
Re: Questions
IIRC 220 should be an all time high for trans tepms
Bradbilt is offline
post #7 of 24 (permalink) Old 04-26-2011, 10:35 PM Thread Starter
DAMN THATS HOT!
Re: Questions
I think I am going to try a new cooler. Like I said though we cleaned the lines so that shouldnt be the problem.
post #8 of 24 (permalink) Old 04-26-2011, 11:19 PM
Re: Questions
Junk the stock cooler and get the biggest aftermarket cooler you can fit. Check your fluid flow..Idle engine and see how long to pump a qt.
email:
Website:
OBSWIZ is offline
post #9 of 24 (permalink) Old 04-27-2011, 02:28 AM
Re: Questions
had the same problem on my cousins truck, junk the stock cooler and get an after market. dropped his temp from 220 to 145. your buck on your third ? sounds like one I had and it was the cps. hope this helps.
94 psd is offline
post #10 of 24 (permalink) Old 04-27-2011, 02:30 AM Thread Starter
DAMN THATS HOT!
Re: Questions
see how long to flow it from the hose into the cooler by unhooking it? I was planning on getting this model cooler.
http://www.transmissioncoolers.us/Me...ool-MAX-cooler
I may ditch the factory drive fan as well and remove the shroud and install several electric fans on switches. any suggestions on good durable fans?
