boost pressure???? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 34 (permalink) Old 04-25-2011, 05:28 PM Thread Starter
boost pressure????
I have 96 f250 with the 7.3,with an automatic tranny. I just put a set of gauges on it and my boost is about 10lbs. Is that normal or is there a problem? I do have a 6 position bullydog chip on it. Its the same on 30 or 50hp. Thanks for any help!
corbread is offline
post #2 of 34 (permalink) Old 04-25-2011, 05:39 PM
Re: boost pressure????
If your seeing a max of 10lbs of boost then you have a leak somewhere, What are your egts?
02 f250
countryboyrob is offline
post #3 of 34 (permalink) Old 04-25-2011, 07:00 PM
95powersmoker's Avatar
Is that at WOT (foot to the floor) or is that like "well I kinda was going from a stop and goosed it for half a second?"
James
2000 F350 CCLB 4x4 auto, 250/200's from PIS, No Limit tunes, Isspro gauges, 4" exhaust and intake.
95powersmoker is offline
post #4 of 34 (permalink) Old 04-25-2011, 07:02 PM
OBS Addict
7.3psd97444's Avatar
Yep if thats at WOT then you got a problem. And I would ditch the bully dog. IMO.
-Jordan-
97 SCLB 7.3 Handshaker
Valair Clutch, only the best.
TS 6 Position Tyrant Tuning
S&B, MBRP, Isspro, Mag-Hytec, 1.00 A/R Exhaust housing, HPX
Full sound system: Kicker-Kenwood
BILLET BADGES
Dick Cepek DC-2's/Duratracs
On-Board Air
Few cosmetics
PSA # 269
7.3psd97444 is offline
post #5 of 34 (permalink) Old 04-25-2011, 07:43 PM Thread Starter
That's really gettin on it! Truck seems to run fine. I haven't got my exhaust guage hooked up yet.
corbread is offline
post #6 of 34 (permalink) Old 04-25-2011, 09:00 PM
excavator's Avatar
I lost boost and all pulling power last week, max boost was 9 or 10.
My fuel pump had 50 psi at idle but low on hard pull. I changed the fuel pump and 15 boost and all the power I need from my stock mason dump
96 F250 XLT 4x4 210000 miles Dana 60, Baby Swamped,Tony Wildman tunes,AutoMeter Pyro Boost Trans ,DPP downpipe,Tymar intake BTS TRANS
e99 f350 cc/lb drw php hydra plus Tony Wildman tune
excavator is offline
post #7 of 34 (permalink) Old 04-26-2011, 12:08 AM Thread Starter
Why should I loose the bullydog, 97444?
corbread is offline
post #8 of 34 (permalink) Old 04-26-2011, 12:12 AM
Depending on how old the bully dog chip is , you may be able to get it reburned with better tunes on it.
02 f250
post #9 of 34 (permalink) Old 04-26-2011, 12:16 AM
I like turtles
NE-STROKE's Avatar
Bullydog is crap on almost all diesels. They are hard on trans and there hp numbers are weak. With a custom tuned chip you will get better mpgs, power, settings, and reliability. Also with bullydog you can not run bigger injectors or hpops correctly.
08 duramax ccsb efi live, air dog 2, isspros, 5 inch exhaust and some other cool things. 2001 duramax 2wd (Project truck)
Once had a signature that had some bad ass stuff on it. Now its back to crap.
NE-STROKE is offline
post #10 of 34 (permalink) Old 04-26-2011, 01:03 AM Thread Starter
Ok thanks. What about my boost problem????
corbread is offline
