lope when hot - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 04-24-2011, 05:01 AM Thread Starter
1997 f250 powerstroke
bryan213's Avatar
Send a message via AIM to bryan213
lope when hot
i noticed the other day when i shut my truck off when its at operating temp and wait about 5 min then start it back up it will lope then lope again then even out and run fine what do u guys think it could be ... scared it might be injectors got i hope its not hah
bryan213 is offline
post #2 of 10 (permalink) Old 04-24-2011, 05:09 AM
Re: lope when hot
when was your last oil change, i thought mine was fine...yeah! ok! just changed mine and my weird idol is gone.
95 f250 ECLB,silver/purple 199k FFD 350/200s, arps, comp 910 shimmed, BTS ZF delete, glowshift EGT,Boost,trans temp,6" aussies,6637, 6.oh IC,dual sd elec fuel. irate T4, S475/96,136k 97 motor. Twin termies
Plans: twin turbs, crowers and fresh rebuild.
rideracelivemx7 is offline
post #3 of 10 (permalink) Old 04-24-2011, 05:10 AM Thread Starter
bryan213's Avatar
Re: lope when hot
hah im accually doing mine tomorro i got the truck a couple months ago have havent done it yet also i notice it dose run a lil weird so ima change it tomorro i was thinking maybe the icp sensor
bryan213 is offline
post #4 of 10 (permalink) Old 04-24-2011, 05:12 AM
GoNavy!
DcMoore999's Avatar
Re: lope when hot
You might try cleaning the IPR.
2000 F-250, RCLB, Auto!!
DcMoore999 is offline
post #5 of 10 (permalink) Old 04-24-2011, 05:16 AM Thread Starter
bryan213's Avatar
Re: lope when hot
whare is the sensor located?
bryan213 is offline
post #6 of 10 (permalink) Old 04-24-2011, 05:35 AM
JFURNER77
JFURNER77's Avatar
Re: lope when hot
Could be a oil problem, could be a fuel problem. Definitely get some new oil in the engine. The IPR is in the rear of the HPOP pump. It may need cleaned, it may need a new o-ring. You may also want to see if the fuel pump is holding 45-50psi. after engine is hot.
1997 F350 4X4 XLT CREW CAB
7.3L POWERSTOKE DIESEL 390,000
T/S 6 POS CHIP, STAGE 1'S, 17* HPOP
6637 AIR INTAKE/NO CAT
4R100 STAGE 3- 12" TRIPLE DISC BILLET TORQ, BILLET INPUT, RED ALTO'S, TUGGER KIT, CUSTOM VALVE BODY, DERALE TURBO PAN.
5" SUSPENSION LIFT, STAINLESS NERF-BARS
16X10 PRO COMP 35X12.50 TOYO OPEN COUNTRY A/T II
JFURNER77 is offline
post #7 of 10 (permalink) Old 04-24-2011, 05:44 AM Thread Starter
bryan213's Avatar
Re: lope when hot
will do i replaced the fuel pump a few months back because the top of the fuel pump was severley leaking
bryan213 is offline
post #8 of 10 (permalink) Old 04-24-2011, 05:48 AM Thread Starter
bryan213's Avatar
Re: lope when hot
now i have to check the fuel pressure when running correct because of the mechanical fuel pump
bryan213 is offline
post #9 of 10 (permalink) Old 04-24-2011, 05:57 AM
JFURNER77
JFURNER77's Avatar
Re: lope when hot
If it is leaking, time to replace. Fuel will lay in the valley under the pump, then run down the back of the engine. Check fuel pressure while running.
post #10 of 10 (permalink) Old 04-24-2011, 02:22 PM
GoNavy!
DcMoore999's Avatar
Re: lope when hot
IPR Kit
http://cw-diesel.com/LuxSite/IPRInfo.htm
