Excessive white smoke, poping from the intake, any help? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 04-24-2011, 03:37 AM Thread Starter
patricku47's Avatar
My buddy bought my 97 from me awhile back and today he had some troubles. He was about 160 miles into I trip when the truck started running awful at a gas station as he was fueling up. A heavy amount of white smoke, a poping sound from the intake, and it doesn't sound like its firing on all 8. No leaks of any kind, rosewood stage 1s that are a year old, fresh fuel filter, and no oil in the fuel. I don't have access to a scanner until Monday. Any ideas on where to start? On the plus side, my 6.0l pulled it home great!
1997 F-350 4x4 CCLB, Rosewood Stage 1's, MBRP 4" exhaust, S&B intake, gauges, 4" lift, 35x12.50 bfg KM2s Sold!!
2006 F-250 ECLB 4x2 6.0 6 speed, tuned, EGR delete, Diesel Site coolant filter, 4" MBRP
patricku47 is offline
post #2 of 12 (permalink) Old 04-24-2011, 03:43 AM
Running at last...
powerstroke cowboy's Avatar
Re: Excessive white smoke, poping from the intake, any help?
Sounds like a Nozzle might have blown off.. Or he bent a Push rod.
My guess is it is injector related or Valve train related..
I hope other with more know how about these engines pipes up..
97 CCLB 4x4 ZF6 [email protected]
powerstroke cowboy is offline
post #3 of 12 (permalink) Old 04-24-2011, 05:42 AM
JFURNER77
JFURNER77's Avatar
As he was fueling up?? Hope he didn't put gas in it.
1997 F350 4X4 XLT CREW CAB
7.3L POWERSTOKE DIESEL 390,000
T/S 6 POS CHIP, STAGE 1'S, 17* HPOP
6637 AIR INTAKE/NO CAT
4R100 STAGE 3- 12" TRIPLE DISC BILLET TORQ, BILLET INPUT, RED ALTO'S, TUGGER KIT, CUSTOM VALVE BODY, DERALE TURBO PAN.
5" SUSPENSION LIFT, STAINLESS NERF-BARS
16X10 PRO COMP 35X12.50 TOYO OPEN COUNTRY A/T II
JFURNER77 is offline
post #4 of 12 (permalink) Old 04-24-2011, 02:56 PM Thread Starter
patricku47's Avatar
Nope he put diesel in it, that was the first thing I asked.
post #5 of 12 (permalink) Old 04-24-2011, 03:18 PM
my 01 did the same thing, smoke lots of it. The motor would start and run and really was quite. Mine had gas in it. My buddy just knew he put diesel in it as the nozzle was green. I had to pull the fuel filter to figure it out. I just thought my rag had gas on it when I took it apart. I then took out the injectors and sent them to swamps for them to tell me I had gas in it. I wouldnt rull it out till I pulled the filter.
2011 6.7 F350 CCSB BLUE SWEET RIDE
1996 F350 BABY SWAMPS AND TS, FLAT DOWNPIPE
semomotorsports is offline
post #6 of 12 (permalink) Old 04-24-2011, 03:22 PM
Popping out the intake is never a good sign. My guess is an intake valve is stuck open.
02 f250
countryboyrob is offline
post #7 of 12 (permalink) Old 04-24-2011, 03:25 PM
Mine popped out of the intake with gasiel mix. Mine would run just didnt sound right and was smoking very bad.
post #8 of 12 (permalink) Old 04-24-2011, 07:03 PM Thread Starter
patricku47's Avatar
Its not gas for sure, I pulled the filter 3 times, it's diesel. I pulled the drivers side valve cover to start checking pushrods and about halfway through I noticed an injector was unplugged. I don't know if it happened while I was pulling pushrods or if it was already unplugged. Could that cause similar symptoms?
post #9 of 12 (permalink) Old 04-24-2011, 07:25 PM
think it would cause a miss. The injector wouldnt fire. But not smoke. I wouldnt think
post #10 of 12 (permalink) Old 04-24-2011, 07:41 PM Thread Starter
patricku47's Avatar
That's what I was thinking, but I have been mistaken once or twice before, I think....
