Blowing smoke and no power - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 04-24-2011, 12:10 AM Thread Starter
Weldon's Avatar
My buddy bought a 1996 f350. He was heading for the house and got a yellow CEL then ran it for another 20 miles then sudden loss of power and motor started loping with smoke, along with pushing oil out of the dip stick tube. Had him check codes he got p111,p0603. looked up threads on these and p0603 battery has been unhooked. Confirmed with him and he replace lift pump a month and a half ago. He cleared that code and another code with a p111 popped up ..which means all clear correct? I'm thinking its a possible bad lift pump or ebpv or ccv... any ideas?
Thanks in advance
Don
1997 f350 cali. 4x4 160K...3" dp/straight out..d66 w/non ebpv...glowshift 3p waiting for install...tymar
Weldon is offline
post #2 of 6 (permalink) Old 04-24-2011, 12:17 AM
oil burner
tughill283's Avatar
Re: Blowing smoke and no power
oil out the dipstick tube sounds pretty serious
96 f250, ZF5,160cc,
300k miles
96 f350 plow truck
tughill283 is offline
post #3 of 6 (permalink) Old 04-24-2011, 12:19 AM
Bushwacker
chevyhurstolds84's Avatar
Send a message via AIM to chevyhurstolds84
sounds like the motor took a poopie
1996 DRW CCLB 2WD 5SPD 430k TOTALED
1984 Hurst/Olds 468 BBC e85 wheelies :)
1991 f150 RCSP 4.9 4x4 best beater in the world!
chevyhurstolds84 is offline
post #4 of 6 (permalink) Old 04-25-2011, 02:40 PM Thread Starter
Weldon's Avatar
He said at wot he only getting 8psi boost on his way home under load. Now he's only getting about 1-2 psi in park @ wot........If he broke a shaft on either turbo or epv...would the exhaust back psi pressurize the system enough to shove dip stick out of tube and cause a bluish smoke with a loss of power? Wouldn't it have to get by piston rings to do this?
Weldon is offline
post #5 of 6 (permalink) Old 04-25-2011, 02:42 PM Thread Starter
Weldon's Avatar
Sorry..edit to last post.... to make it smoke a blue smoke...thats fuel correct?
Weldon is offline
post #6 of 6 (permalink) Old 04-25-2011, 02:52 PM
OBS Addict
7.3psd97444's Avatar
If your only getting 8 psi boost then you got a boost leak somewhere. 1-2 psi at dead stop is normal. Oil outa the dip now that's wierd....understand that some smoke is normal. Smell the exhaust. See if t smells like oil or fuel.
-Jordan-
97 SCLB 7.3 Handshaker
Valair Clutch, only the best.
TS 6 Position Tyrant Tuning
S&B, MBRP, Isspro, Mag-Hytec, 1.00 A/R Exhaust housing, HPX
Full sound system: Kicker-Kenwood
BILLET BADGES
Dick Cepek DC-2's/Duratracs
On-Board Air
Few cosmetics
PSA # 269
7.3psd97444 is offline
