clearing codes - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 04-22-2011, 08:50 PM Thread Starter
clearing codes
How do I clear the codes from the pcm on a 97 powerstroke.
johnpline is offline
post #2 of 7 (permalink) Old 04-22-2011, 08:51 PM
Re: clearing codes
You need a code reader that has the abilty to read and scan the codes on these trucks.
02 f250
countryboyrob is offline
post #3 of 7 (permalink) Old 04-22-2011, 08:55 PM Thread Starter
Re: clearing codes
#### ok i was able to get the codes out of it with a oreillys code reader but i don't know if it well remove them after i replace the cps and icp
post #4 of 7 (permalink) Old 04-22-2011, 08:57 PM
Re: clearing codes
It should give the option to clear the codes depending on how good the scanner is.
02 f250
post #5 of 7 (permalink) Old 04-22-2011, 11:59 PM
blageurt's Avatar
Re: clearing codes
Disconnect the batteries for 5 minutes ....
95 E350 Cargo, E4OD , B/M aluminium Pan / 2 HD Trans coolers , Dana 60FF 3:55 , 140 V idm , Autometer guages , TDEO Dp flashed 60 Tow , EBPV delete , BB shim , cat sleeps with the fishes, Timbren SES, stage 1's coming soon
blageurt is offline
post #6 of 7 (permalink) Old 04-23-2011, 12:02 AM
Re: clearing codes
How can I forget something that easy
02 f250
post #7 of 7 (permalink) Old 04-23-2011, 05:34 AM Thread Starter
Re: clearing codes
Thanks guys kind of learning not used to having to work on it myself. Ill just unhook the batteries while im changing the icp and the oil tomorrow.
