Calli truck fuel pump ? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 04-22-2011, 03:03 PM Thread Starter
A buddy of mine bought a 96 from callifornia and the fuel pump is leaking. My question is, does the turbo have to come off to get it out with that dampener on the back of the pump? If not how do you do it?
1994 F-350 4x4 RC 7.3 IDI Turbo, BTS E-4OD, ATS upgrades, BB injectors, Moose Pump, Holley Red.
1997 F-350 CC 4x4 7.3, E-4OD, 6" lift, 38" swampers, 160/80% RDS injectors, TDP tunes.
2001 F-250 RC 4x4 7.3, 4R-100, Straight piped, PHP tune, Western 8.5 MVP.
2003 E-350 7.3, 4R100, 3.55LS. Stock(For now)
t444epsd is offline
post #2 of 4 (permalink) Old 04-22-2011, 08:22 PM
OBS Addict
7.3psd97444's Avatar
Re: Calli truck fuel pump ?
Im pretty sure the cali trucks are the same as others in this perspective. No you dont have to take the turbo off to change the pumps. Everything unbolts and comes right out. Drain the fuel bowl first so you dont flood the engine valley.
-Jordan-
97 SCLB 7.3 Handshaker
Valair Clutch, only the best.
TS 6 Position Tyrant Tuning
S&B, MBRP, Isspro, Mag-Hytec, 1.00 A/R Exhaust housing, HPX
Full sound system: Kicker-Kenwood
BILLET BADGES
Dick Cepek DC-2's/Duratracs
On-Board Air
Few cosmetics
PSA # 269
7.3psd97444 is offline
post #3 of 4 (permalink) Old 04-22-2011, 09:06 PM
Patrick Feeley's Avatar
I think its a bit more difficult on the Cali split trucks, but I've heard it can be done. I really need to get out and look at mine so I can make a special tool if needed. Cheers!
Patrick Feeley is offline
post #4 of 4 (permalink) Old 04-22-2011, 11:17 PM
morefuel's Avatar
Yes it can be changed without removing the turbo. Not sure if you must remove the damper also or not but it is a pain in the butt.
97 f250, ZF-5 tranny, 6637, 3" round downpipe 5" exhaust, PHP six position, 6.0 liter I/C, DIY exhaust brake, 05 axle swap, 280HP 551 ft. lbs.
morefuel is offline
