Fuel leak from bottom of engine - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 04-22-2011, 04:18 AM Thread Starter
deezeljunky's Avatar
Hey guys i got a 1997 250 7.3 psd thats leaking fuel from the bottom of the engine. It drips down from the cover of the flywheel. It leaves about a 5 inch puddle when i park it. Somtimes it will leak bad, sometimes it will barley drip. I was wondering what this might be, whether its a big problem or not, or if its somthing i shouldnt worry about. I currently have a ts chip and 6637 intake on it. Any help or suggestions greatly appreciated, thanks!
deezeljunky is offline
post #2 of 4 (permalink) Old 04-22-2011, 04:20 AM
Built not Bought
1990 Scorpion's Avatar
Re: Fuel leak from bottom of engine
Check around your fuel pump in the valley, look over the hoses for cracks. Also look over your fuel bowl see if it's coming from around there. There are lots of common spots in these areas that leak, then drain down the back of the motor.
1996 7.3L Powerstroke
T6 Chip with Tony Wildman Tunes
Autometer Cobalt Gauges
3 inch DP, 5 inch Straight Pipe
S&B Intake
Billet Torque Converter, Triple Kevlar Clutches, Transgo Shift Kit.
1990 Scorpion is offline
post #3 of 4 (permalink) Old 04-22-2011, 08:35 AM
Moderator
PsRumors's Avatar
+ check at the back of the heads where the steel fuel line meets the fitting. Those Vibra-Lok fittings can dry out over time and leak.
'97 SCLB 4x4, 3.55, D60 w/ TrueTrac, 6637, Banks Techni-cooler, BTS Trans, Tru-Cool 4921 Trans Cooler, 1.0 exhaust housing, no ebv, 3" DP, Straight Exhaust, E-Fuel, TW tunes, International WP, 203*, Isspro Gauges
PsRumors is offline
post #4 of 4 (permalink) Old 04-22-2011, 01:49 PM Thread Starter
Alright, will do. Ill post my findings.
