code questions - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 04-21-2011, 09:15 PM Thread Starter
code questions
I was finally able to pull codes out of my truck. The codes that should up Where the p1280,p0603,p0344. I know what they all mean but I just want to double check some stuff. The P0344 is the cps so I replaced it, was this the correct thing to do? The P1280 is the icp, does this mean the ICP is bad? And what causes the P0603 kAM? I also replaced the batteries and alternator last weekend.
johnpline is offline
post #2 of 4 (permalink) Old 04-21-2011, 09:38 PM
Busted Knuckles
PSDEng's Avatar
Re: code questions
KAM can be caused by taking the batteries out or putting a chip in so that is probably where it came from. Your icp code probably means your oil pump is not up to par.
'97 Powerstroke SCLB:
i have a couple friends that went balls deep in wyotech and when they got out they couldn't poor piss out of a boot if you put the directions on the sole
PSDEng is offline
post #3 of 4 (permalink) Old 04-21-2011, 09:57 PM Thread Starter
Re: code questions
when i unplugged the icp it had oil in the connection
post #4 of 4 (permalink) Old 04-21-2011, 10:05 PM
Busted Knuckles
PSDEng's Avatar
Re: code questions
Ok then yes you are right that will need replaced.
PSDEng is offline
