On the road again. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 04-21-2011, 03:17 PM Thread Starter
Goldknight's Avatar
On the road again.
Woo hoo!!!!
After months of chasing down little issues after rebuilding my motor she is back on the road for good.
I put 300 miles on her in the last 2 days averaging 18 to 15 miles per gallon.
I did come up with a few more issues to resolve.
1 the clutch grabs and shutters when taking off.
2 the starter bolts backed out.
3 a few oil leaks showed up
That is about it. over all i cant be more happy the truck runs and drives great.
If any ones wondering it is a 96 CC LB 5 speed.
And i think it has the lowest gears in the world. 2300 rpms at 65 in 5th gear. I will have to look into that.
Goldknight is offline
post #2 of 10 (permalink) Old 04-21-2011, 04:37 PM
OBS Addict
7.3psd97444's Avatar
Re: On the road again.
Nice.
I got 4:10's and sit at about 2 grand at 65 mph. 5th gear.
-Jordan-
97 SCLB 7.3 Handshaker
Valair Clutch, only the best.
TS 6 Position Tyrant Tuning
S&B, MBRP, Isspro, Mag-Hytec, 1.00 A/R Exhaust housing, HPX
Full sound system: Kicker-Kenwood
BILLET BADGES
Dick Cepek DC-2's/Duratracs
On-Board Air
Few cosmetics
PSA # 269
7.3psd97444 is offline
post #3 of 10 (permalink) Old 04-21-2011, 04:40 PM
bluedge8's Avatar
good job, double check your rpms though, that seems high actually
1997 f250 4x4 sclb, auto, 3.55's, 191k, diy intake w 6637, ccv mod, pyro, boost, trans gauges, 3" dp to 4" single exh. super chips for now. scangauge
Originally Posted by jdc753 View Post
Besides there is absolutely no way to idiot proof something, since they are always coming out with better idiots by the day
bluedge8 is offline
post #4 of 10 (permalink) Old 04-21-2011, 07:10 PM Thread Starter
Goldknight's Avatar
Thanks.
I think it may be the speed that off. I have 315/70/16 on there and I doubt the speedo has been re calibrated. I will use my gps to double check it.
Did they make lower gears to 4.11?
post #5 of 10 (permalink) Old 04-22-2011, 02:12 AM
bluedge8's Avatar
obs right?, stock gears are 3.55's or 4.10's you are taching higher than 4.10's if your speed is accurate.
bluedge8 is offline
post #6 of 10 (permalink) Old 04-22-2011, 05:41 PM Thread Starter
Goldknight's Avatar
Speedo cal. was way off. Fixed it a few ago. I will see after work if it makes a big diff. I sure hope this is the case. I am not in the mood to change gears.
yes its a obs. a 96.cclb
post #7 of 10 (permalink) Old 04-22-2011, 05:58 PM
OBS junkie
Cat_Rebel's Avatar
With 315s your speedo should be 5mph slow. So when it says your doing 65mph you are really doing 70mph.
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Cat_Rebel is offline
post #8 of 10 (permalink) Old 04-22-2011, 06:04 PM
wrenchturner250's Avatar
Sounds right to me I have 4.10s and 315s at 65 that's about right with my new injectors and no chip I pulled 19mpg and one tank then 17.5 on the others
2007 f250 Sd fx4
Arp's, 4"dp 5" straight pipe with 7" stack,S&B intake, no limit cold side, blue spring, 6.4 banjos, gauges, 2.5" leveling kit,sct with gearhead tunes, egr delete and coolant filter warren 175s, powermax
wrenchturner250 is offline
post #9 of 10 (permalink) Old 04-22-2011, 09:37 PM Thread Starter
Goldknight's Avatar
Perfect Thanks for the info guys.
I need to put a limited slip in the rear end. I cant touch the gas in 1 and 2nd without the tires spinning. And yes i am on dirt roads. grin.. 90% of my driving in on dirt. Got to love living in the boonies
post #10 of 10 (permalink) Old 04-23-2011, 05:33 PM Thread Starter
Goldknight's Avatar
Adjusted the speedo and every thing looks much better now. 65mph at about 2K.
I am spending way to much in gas but I am having a ball driving this truck around. At this rate i may hit that 10K mile break in by years end hahahah..
Next on the list is shocks. Really want to find a dual shock system for the front.
Keep it between the lines? bah wheres the fun in that.....
