possibly buying another obs - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 49 (permalink) Old 04-21-2011, 06:04 AM Thread Starter
swamp_ratt's Avatar
gonna maybe go look at a 97 cclb 4x4 auto tomorrow with 174k on it. he says it needs pcm, turbo and power steering pump. it has a new idm, new reman trans, dayco converter and shift kit, 3 inch dp and 4 inch dp back. i was going to bring one a my manual trans pcm to see if it starts. i will bring some tools and an ohm meter to pop off valve covers and check uvch's and vcg's and ohm injectors. what else should i be looking for? thanks
1995 F350 CCLB DT360/Allison
1997 F350 RCLB 460/E40D
2001 Jetta TDI 5spd (51mpg work beater)
1995 F350 CCLB 2.5 tons/57s Front, 53s Rear
swamp_ratt is offline
post #2 of 49 (permalink) Old 04-21-2011, 04:42 PM
OBS Addict
7.3psd97444's Avatar
Re: possibly buying another obs
Unessasary leaks, signs of neglect obviously. You say it's missing a turbo make sure nothing has gotten in the intake while it's been sitting without a turbo. Other than that sounds like you know what your doing.
On edit: if it has the TTB front axle make sure it isn't about to junk.
-Jordan-
97 SCLB 7.3 Handshaker
Valair Clutch, only the best.
TS 6 Position Tyrant Tuning
S&B, MBRP, Isspro, Mag-Hytec, 1.00 A/R Exhaust housing, HPX
Full sound system: Kicker-Kenwood
BILLET BADGES
Dick Cepek DC-2's/Duratracs
On-Board Air
Few cosmetics
PSA # 269
7.3psd97444 is offline
post #3 of 49 (permalink) Old 04-21-2011, 05:02 PM
bluedge8's Avatar
I wouldn't diag too much in front of the guy, lots of these trucks are mis diagnosed, I would check the turbo for dusting and general wear and tear to the vehicle and make an educated guess. if the motor and trans are solid, (guess, i know) the rest wont be too bad to sort out. I have a turbo for it, I don't know the condition of this turbo, but i'm sure it could be rebuilt. where is the truck? let us know what you find.
1997 f250 4x4 sclb, auto, 3.55's, 191k, diy intake w 6637, ccv mod, pyro, boost, trans gauges, 3" dp to 4" single exh. super chips for now. scangauge
Originally Posted by jdc753 View Post
Besides there is absolutely no way to idiot proof something, since they are always coming out with better idiots by the day
bluedge8 is offline
post #4 of 49 (permalink) Old 04-21-2011, 05:52 PM Thread Starter
swamp_ratt's Avatar
Truck is in st cloud. I have everything needed to fix it except the pcm. I only have a manual trans pcm. I stripped my truck down to bare frame for a rebuild so everything is layin on my garage floor
post #5 of 49 (permalink) Old 04-21-2011, 06:05 PM
OBS Addict
I thought you could use a manual trans pcm in an auto? Or is the other way around?
-Jordan-
BILLET BADGES
On-Board Air
Few cosmetics
PSA # 269
post #6 of 49 (permalink) Old 04-21-2011, 06:09 PM
bluedge8's Avatar
if you need any help let me know, I'm about 20mins away.
bluedge8 is offline
post #7 of 49 (permalink) Old 04-21-2011, 06:25 PM
I know nothing...
joedaddy's Avatar
Cclb won't be ttb.
Doesn't roll with anyone or tag along to be cool...
joedaddy is offline
post #8 of 49 (permalink) Old 04-21-2011, 06:33 PM
OBS Addict
Originally Posted by joedaddy View Post
Cclb won't be ttb.
ok thanks i didnt know that
-Jordan-
BILLET BADGES
On-Board Air
Few cosmetics
PSA # 269
post #9 of 49 (permalink) Old 04-21-2011, 06:40 PM
I know nothing...
joedaddy's Avatar
Cclb only came in F350-1ton-D60 solid.
Ccsb only come in F250-3/4ton-D50 ttb.
joedaddy is offline
post #10 of 49 (permalink) Old 04-21-2011, 06:49 PM
OBS Addict
ok i see thank you.
-Jordan-
BILLET BADGES
On-Board Air
Few cosmetics
PSA # 269
