Dually Swap - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 04-20-2011, 11:35 PM Thread Starter
I Like Red Cows
deercreekstroker's Avatar
Send a message via MSN to deercreekstroker
Dually Swap
I fount a '95 Reg Cab F-350 Gas 4x4 Dually, would the front and rear ends swap over to my '96 Reg Cab Dually?
Also if after I do this (after I do some power mods) would I be able to pull say a 28'-30' gooseneck Stocktrailer Fully loaded?
deercreekstroker is offline
post #2 of 6 (permalink) Old 04-20-2011, 11:49 PM
Re: Dually Swap
I want to say yes and Yes.
02 f250
countryboyrob is offline
post #3 of 6 (permalink) Old 04-21-2011, 01:29 AM
STILL LEARNING
Bradbilt's Avatar
Re: Dually Swap
Is the 95 a cab-n-chassis or a conversion?
Is your 96 a pick up or cab-n chassis?
Bradbilt is offline
post #4 of 6 (permalink) Old 04-21-2011, 01:58 AM Thread Starter
I Like Red Cows
Re: Dually Swap
well the '95 has a utility bed on it. my '96 had a box until aug. then got a flatbed slapped on it.
post #5 of 6 (permalink) Old 04-21-2011, 02:58 AM
Just another OBS addict
rancherstroker6's Avatar
Re: Dually Swap
You need to measure the frame width on the 95 and compare it to your 96. If the 95 is a real cab n chassis, the frame will be narrower, therefore the spring perches will be narrower and require modification. Otherwise, if it's not a cab n chassis, then to answer your questions, yes and yes. Also, on the front springs, you must also consider the spring rates. If it's a small block, such as a 351 instead of a 460 big block, you'll need big block/diesel springs to support the PSD weight. Ford made 2 different spring rates, one for small blocks, and one for big blocks and diesels.
1995 F250 SCLB 4X4 Auto - '97 D60/10.5" rear, 4.5" PMF RSK/V's, PMF Trac Bars, Sway Bars, MBRP Exhaust, DP F5, Efuel, RRD Diff Cover, Tymar Intake, Isspro Performaxs/Quad Pod, Recon Cab Lights, 05 Lariat SD Steering Wheel
FF250/2's, ARP Studs, Comp Beehives, Smith Bros Pushrods, 1.15 38r, RRD Boost Fooler, 99.5+ Intake, SD 7.3 IC
rancherstroker6 is offline
post #6 of 6 (permalink) Old 04-21-2011, 10:03 AM
STILL LEARNING
Bradbilt's Avatar
Re: Dually Swap
Bradbilt is offline
