97 icp questions - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 04-20-2011, 09:31 PM Thread Starter
97 icp questions
I have some running problems with starting and dying with cel on after two times it goes away and no cel. Tried pulling codes and with several different readers found nothing. I was told to check the connections to several things one being the icp when i unplugged it there is oil on the plug end and in the icp. When i unplugged it and started it it stopped dying and the cel stayed on. Does this mean it is bad? It idles better with it unplugged than plugged in.
johnpline is offline
post #2 of 4 (permalink) Old 04-20-2011, 09:41 PM
Re: 97 icp questions
I would say yes, time to replace the icp sensor.
02 f250
countryboyrob is offline
post #3 of 4 (permalink) Old 04-21-2011, 03:15 AM
Harl
Harl's Avatar
Send a message via AIM to Harl
Dont mean to derail the thread but is the truck suposed to stay running when you unplug the icp?? Mine runs like CRAP with it pluged in. Truck jerks so bad and wont stop unless you smash it to the floor or just let all that way out... So i just run around with it unpluged and it runs WAY better.. Any ideas?
Cody,17
DD-1996 F250 Powerstroke, 5speed, 4x4 ecsb
Mods: GlowShift Gauges-Boost, Pryo, Oil psi and Fuel psi. DIY 6637 Intake, 160/100's, Wildman 6pos, Stage 2 water/meth, D66, TE HPOP, Vailer Clutch, Custom Bars and 5in turbo back....
PT-1995 F350- totaled
Soon to be brought back to a 1992
Harl is offline
post #4 of 4 (permalink) Old 04-23-2011, 10:18 PM
<-Friends bike
If its leaking you need a new one . It may not fix all the issues , may need a new IPR
Rick....
Supporter/End user of ShiftSolutions THE CURE E4/4R Trans Control. Helping Cancer patients and families
Special thanks to RacerX USA
ActionRick is offline
