truck won't start... - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 04-20-2011, 05:19 PM Thread Starter
No matter how many times I turn it truck won't start in weather under 50.
Glow plugs?
Anyone know how to check for proper voltage on glow plugs?
Thanks
philipcrabbak is offline
post #2 of 8 (permalink) Old 04-20-2011, 05:45 PM
95powersmoker's Avatar
Re: truck won't start...
Use a multimeter at the UVCH plugs... Two per bank. Two outside pins are glow plugs. A good glow plug will read between 0.8 - 1.2 ohms a weak glow plug will have much less resistance, and a completely dead one will have unlimited resistance through it because the electrode is internally burned out.
Also, test the relay.
James
2000 F350 CCLB 4x4 auto, 250/200's from PIS, No Limit tunes, Isspro gauges, 4" exhaust and intake.
95powersmoker is offline
post #3 of 8 (permalink) Old 04-20-2011, 06:34 PM
That's weird that it doesn't start you should be able to start it at 50 without gp. I've started trucks in the 30's with bad or no glow plugs. id check the glow plugs and relay anyway though
cfdeng7 is offline
post #4 of 8 (permalink) Old 04-20-2011, 06:39 PM
Do u have any smoke while cranking?
cfdeng7 is offline
post #5 of 8 (permalink) Old 04-21-2011, 07:23 AM Thread Starter
yes i have quite a bit of smoke when cranking. This Bad?
post #6 of 8 (permalink) Old 04-21-2011, 09:50 AM
Built not Bought
1990 Scorpion's Avatar
No white smoke is just incomplete combustion so it shows you're getting fuel.
1996 7.3L Powerstroke
T6 Chip with Tony Wildman Tunes
Autometer Cobalt Gauges
3 inch DP, 5 inch Straight Pipe
S&B Intake
Billet Torque Converter, Triple Kevlar Clutches, Transgo Shift Kit.
1990 Scorpion is offline
post #7 of 8 (permalink) Old 04-21-2011, 04:33 PM
OBS Addict
7.3psd97444's Avatar
This happened to me. It's normal. Cept the 50* part. Mine wouldn't start below 35-40 and it was the siliniod. Mine would start after about 10 tries though.
-Jordan-
97 SCLB 7.3 Handshaker
Valair Clutch, only the best.
TS 6 Position Tyrant Tuning
S&B, MBRP, Isspro, Mag-Hytec, 1.00 A/R Exhaust housing, HPX
Full sound system: Kicker-Kenwood
BILLET BADGES
Dick Cepek DC-2's/Duratracs
On-Board Air
Few cosmetics
PSA # 269
7.3psd97444 is offline
post #8 of 8 (permalink) Old 04-23-2011, 08:02 AM Thread Starter
thanks for the help i'll look into it
