truck wont start, makes clicking sound - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 37 (permalink) Old 04-20-2011, 03:45 AM Thread Starter
baggedbug's Avatar
my truck had been sounding like it was getting harder to start. Last week it wouldnt start for me, just made a clicking sound. I changed the starter and it fired right up. now getting ready to leave work today it wouldnt start again. I had a starter selonoid in the truck, thought that might be the problem. Changed them out and still wouldnt start, same clicking sound as before. Any ideas to check before I have it towed to a mechanic?
baggedbug is offline
post #2 of 37 (permalink) Old 04-20-2011, 03:48 AM
95powersmoker's Avatar
Re: truck wont start, makes clicking sound
Check all the wiring on the starter... Did you try jumping the starter solenoid?
James
2000 F350 CCLB 4x4 auto, 250/200's from PIS, No Limit tunes, Isspro gauges, 4" exhaust and intake.
95powersmoker is offline
post #3 of 37 (permalink) Old 04-20-2011, 03:52 AM Thread Starter
baggedbug's Avatar
yea, used a bolt to jump the 2 large post. didnt do anything but click like before.
post #4 of 37 (permalink) Old 04-20-2011, 04:14 AM
FordCowboy's Avatar
How are you batteries? And the connections on the batteries?
Early 99 Powerstroke
Crew Cab Short Bed Lariat 4x4
SCT Livewire w/ various custom tunes
Adrenaline
AFE stage 2
Super 66 Turbo
4" straight pipe
Modded IDM
Automatic trans: PI Converter, tugger kit
Leveling Kit w/ 35's
FordCowboy is offline
post #5 of 37 (permalink) Old 04-20-2011, 04:22 AM
i would check the wiring to the batteries. my truck was doing the same thing, the wires are one huge a$$ harness that connects the two batteries then goes to the starter and soliniod. any corision will make it hard to start, think of it like a garden hose and there is a rock jammed in there, sure it will run but not very good. now back to the issue... on my truck i replaced the starter, solonoid, and battery wiring harness and it started right up.
zappattack18 is offline
post #6 of 37 (permalink) Old 04-20-2011, 05:18 AM Thread Starter
baggedbug's Avatar
Will check the harness and wiring to the starter tomorrow. Thanks for the imput guys. I was so pissed off today I just left it at work. Its just one thing after another with her lately.
post #7 of 37 (permalink) Old 04-20-2011, 02:29 PM
Cratos's Avatar
I had the main wire from the batter pull out of the lug it was doing the same thing check all your connections and batt condtion I had one the looked good in till you hit the started then is showed 0 voilt with any load on it.
Blue 2012 XLT SCLB 4X4 , 38,550 miles, 3:55's & 18's Camper and Tow packages. Edge insight, Airlift Wireless compressor & Air Bag set-up, Dieslesite filter.
Cratos is offline
post #8 of 37 (permalink) Old 04-21-2011, 07:03 PM Thread Starter
baggedbug's Avatar
Checked voltage at batteries, and starter and had 12 volts before and trying to start. Checked all wires. They seem good. A guy at work told me it might have a parking safety switch. Is this true? How could I check if it does?
post #9 of 37 (permalink) Old 04-21-2011, 07:38 PM
OBS junkie
Cat_Rebel's Avatar
If your neutral safety switch went bad you would still be able to start it by jumping the solenoid. Had 1 go bad on my 93 & it did that. I'd pull the connections off your battery's & clean them off good, grease them (I just use bearing grease) then reinstall & tighten down good. I've seen that fix a lot of issues (even when the voltage was good on the battery's) & it won't cost you anything but an hour to try.
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Cat_Rebel is offline
post #10 of 37 (permalink) Old 04-21-2011, 07:45 PM
How old is the starter?
02 f250
countryboyrob is offline
