Boost question - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 04-20-2011, 03:57 AM Thread Starter
Boost question
I just bought a 97 f250. My boost Gage reads about 4 psi at
75 mph. Is that normal or low? Also the pyro is running anywhere between 650 an 750 at the same is that to high?
Doorhanger 97 is offline
post #2 of 4 (permalink) Old 04-20-2011, 04:47 AM
95powersmoker's Avatar
Re: Boost question
It's about normal for cruising down the highway... Same with the temps...
James
2000 F350 CCLB 4x4 auto, 250/200's from PIS, No Limit tunes, Isspro gauges, 4" exhaust and intake.
95powersmoker is offline
post #3 of 4 (permalink) Old 04-20-2011, 07:35 AM
Just another OBS addict
rancherstroker6's Avatar
Re: Boost question
Seems about normal on the boost, mine runs more like 5-6 IIRC. And the temp seems about right, maybe a little high, depends on how much you're givin' er (such as traffic, terrain, etc.), takes a little to keep these things up to that kinda speed.
1995 F250 SCLB 4X4 Auto - '97 D60/10.5" rear, 4.5" PMF RSK/V's, PMF Trac Bars, Sway Bars, MBRP Exhaust, DP F5, Efuel, RRD Diff Cover, Tymar Intake, Isspro Performaxs/Quad Pod, Recon Cab Lights, 05 Lariat SD Steering Wheel
FF250/2's, ARP Studs, Comp Beehives, Smith Bros Pushrods, 1.15 38r, RRD Boost Fooler, 99.5+ Intake, SD 7.3 IC
rancherstroker6 is offline
post #4 of 4 (permalink) Old 04-20-2011, 02:54 PM Thread Starter
Re: Boost question
Thanks
