Anti Theft light flashing and no start HELP - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 04-20-2011, 03:02 AM Thread Starter
What controls the injector timing? How could the anti-theft disable the truck so it wont start?
prerunner007 is offline
post #2 of 9 (permalink) Old 04-20-2011, 03:39 AM
OEM Moderator
Tom S's Avatar
Re: Injector timing on a 95.
PCM via the CPS
What are you wanting to do in regard to anti theft
Tom S is offline
post #3 of 9 (permalink) Old 04-20-2011, 03:47 AM Thread Starter
The anti-theft light is flashing and I beleive its not allowing the truck to fire. HPOP has oil in it, tach is moving, wts light cycles like normal. Fuel pump is filling filter housing. I am lost. What is the cmp. The camshaft position sensor? Where would the pcm be located ?
post #4 of 9 (permalink) Old 04-20-2011, 04:57 AM Thread Starter
Does anybody like to answer?
post #5 of 9 (permalink) Old 04-20-2011, 06:25 AM
95powersmoker's Avatar
Not sure what the cmp is... The PCM is located behind the ebrake assembly.
James
2000 F350 CCLB 4x4 auto, 250/200's from PIS, No Limit tunes, Isspro gauges, 4" exhaust and intake.
95powersmoker is offline
post #6 of 9 (permalink) Old 04-20-2011, 03:06 PM
OEM Moderator
Tom S's Avatar
Re: Anti Theft light flashing and no start HELP
Is it possible that your truck as an aftermarket alarm and/or system installed that uses the anti theft light on the dash that has been triggered? I did not think these trucks had anti theft from the factory but I could be wrong. I do not recall anyone else with this issue either.
Tom
Tom S is offline
post #7 of 9 (permalink) Old 04-23-2011, 09:53 AM
Cool Re: Anti Theft light flashing and no start HELP
This may or may not help but it's worth looking into. 3 weeks ago I had the same thing happen to me after I washed my engine down at the car wash. It turned out to be the fuse going to the ignition cause a noise suppressor got shorted out and caused a 90 amp load on the ignition. (not on a diesel) but it's possible that you could have something similar. Mine wouldn't even crank and my factory alarm light was flashing. Just a thought good luck..
M1009cucv11 is offline
post #8 of 9 (permalink) Old 04-24-2011, 02:16 AM
According to both the owner's manual and the FSM, unlocking the door with the key should disarm the anti-theft. It specifically says you should turn the key as far as it will go. It might be worth unlocking the passenger door with the key, in case the switch on the driver's side is inop.
madpogue is offline
post #9 of 9 (permalink) Old 04-24-2011, 02:42 AM
you have a 94-97 diesel with some sort of pats? I wasn't aware anything (diesels) but excursions came with anti theft.
ddillenger is offline
  LinkBacks (?)
LinkBack to this Thread: https://www.powerstrokenation.com/forums/17-1994-1997-power-stroke-technical-info/100571-anti-theft-light-flashing-no-start-help.html
Posted By For Type Date
Changed oil, no start - Page 2 - Ford Truck Enthusiasts Forums This thread Refback 12-19-2015 10:50 PM
