Quick Question - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 04-20-2011, 12:15 AM Thread Starter
Built not Bought
1990 Scorpion's Avatar
Quick Question
Hey guys I'm just lookin for advice to calm my thinking. A little over 2,000 miles ago I changed my oil with 5W-40 Rotella T6 Synthetic and added some Rev-X oil additive.
Periodically I check my oil (about once or twice every two weeks) well after over 2,000 miles I haven't lost or gained any oil, it's always stayed right around the full mark on the dipstick. Also I only check it after the Truck has been sitting a bit to let the oil drain back down a bit.
The oil smells good, doesn't smelt burnt or like diesel just smells like oil that's been running through the motor. Should I be worried about not having any oil consumption? Any thoughts or opinions on this are welcome.
1996 7.3L Powerstroke
T6 Chip with Tony Wildman Tunes
Autometer Cobalt Gauges
3 inch DP, 5 inch Straight Pipe
S&B Intake
Billet Torque Converter, Triple Kevlar Clutches, Transgo Shift Kit.
1990 Scorpion is offline
post #2 of 4 (permalink) Old 04-20-2011, 11:26 PM
blageurt's Avatar
Re: Quick Question
Why would you worry about that.... Its when you start USING oil that you need to worry a little.... I use the Rotellas 15W40 regular oil , and My truck uses /leaks 1- 1.5 litres between changes (10,000 kms) and that is Normal I was told ...
95 E350 Cargo, E4OD , B/M aluminium Pan / 2 HD Trans coolers , Dana 60FF 3:55 , 140 V idm , Autometer guages , TDEO Dp flashed 60 Tow , EBPV delete , BB shim , cat sleeps with the fishes, Timbren SES, stage 1's coming soon
blageurt is offline
post #3 of 4 (permalink) Old 04-21-2011, 03:01 AM
Bugman's Avatar
Re: Quick Question
I agree. Were you using oil before the swap?
Bugman is offline
post #4 of 4 (permalink) Old 04-21-2011, 04:45 AM Thread Starter
Built not Bought
Re: Quick Question
Yea before I changed oil brands I previously went through about 2 quarts in between oil changes
S&B Intake
