95 F250 wont start. Is there a fuel pump in the tank? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 04-19-2011, 05:15 AM Thread Starter
What feeds the lift pump? No way it sucks all the way to the tank? What relay and or fuse could it be? Still have the theft light flashing.
prerunner007 is offline
post #2 of 8 (permalink) Old 04-19-2011, 05:20 AM
Re: 95 F250 wont start. Is there a fuel pump in the tank?
The cam-driven pump is the primary. Just like most cars and trucks had well into the '80s, and some right up into the '90s. Anti-theft is probably what's still disabling the truck.
madpogue is offline
post #3 of 8 (permalink) Old 04-19-2011, 05:37 AM Thread Starter
Any Idea how to disable the antitheft? Any help is appreciated. Is there a P. A. T. S. system on a 95?
post #4 of 8 (permalink) Old 04-19-2011, 05:02 PM
biggreen96's Avatar
No a 95 does not have a p.a.t.s
96 cclb f350.
idm mod,
gauges-boost/pyro/trans temp
afe stage 2 intake
dp to 4" straight pipe
studs, springs, pushrods
srp1
intercooler
electric fuel convertion
238/100
dp-tuner f6
T-4 mount and s470.
biggreen96 is offline
post #5 of 8 (permalink) Old 04-24-2011, 03:45 PM
Cratos's Avatar
is it not puling fuel form either tank? there is no in tank pump on our trucks just the one in the valley your pump could be bad ot a hole in a rubber line letting air in the system fuel pickups in tanks could be plugged from bad fuel ot the tank pick-ups could have rotted off. from age and this junk fuel that the gov made us switch to.
did it just not start ? or did it just keep geeting wprse. no info on your troubles would help.
Blue 2012 XLT SCLB 4X4 , 38,550 miles, 3:55's & 18's Camper and Tow packages. Edge insight, Airlift Wireless compressor & Air Bag set-up, Dieslesite filter.
Cratos is offline
post #6 of 8 (permalink) Old 04-24-2011, 03:48 PM
they do have theft systems, I have a 94.5 and the door was opened from the outside by reaching through and useing the inside handle. It set it off had to unhook the batterys as we dont have a door key.
2011 6.7 F350 CCSB BLUE SWEET RIDE
1996 F350 BABY SWAMPS AND TS, FLAT DOWNPIPE
semomotorsports is offline
post #7 of 8 (permalink) Old 04-24-2011, 08:23 PM
jim
i have the same problem with a 95 i just bought that was hit in the nose driverside. There is no fuel in the filter and i believe it has an aftermarket alarm. It has fuel in the tanks but not in the filter. Is there a fuel reset switch or could it be the alarm?
jmiller9339 is offline
post #8 of 8 (permalink) Old 04-30-2011, 03:54 PM Thread Starter
How can you test the PCM to see if its functioning properly? Something electronic is telling it to not start. There is fuel in the bowl. The fuel rises as you crank. There is fuel at the back of the heads. Anti theft must have killed the starting circuit? Help!!!
