97 rough idle and no power - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 35 (permalink) Old 04-19-2011, 04:25 AM Thread Starter
hey guys as the title says i have a 1997 powerstroke that has been running perfect untill today on my lunch break i went to start it, everything was normal untill 45 seconds in the idle went to crap and the truck died, i was able to get it started and limped it home, with no power...couldnt get over 10mph.... the truck will start but the idle sounds horrible, like its missing or running on 5 cylinders or the combustion in the cylinders is going on at the wrong time.... this was completly out of the blue and havent had any problems untill now... any thoughts please?
thanks fellas
zappattack18 is offline
post #2 of 35 (permalink) Old 04-19-2011, 05:58 AM
Laces Out
bigrpowr's Avatar
Re: 97 rough idle and no power
thanks fellas
what about this has to do with being stuck on the side of the road broken down? moved to say the least.
08' F250 4x4 w/ 3:55's
bigrpowr is offline
post #3 of 35 (permalink) Old 04-19-2011, 06:00 AM
95powersmoker's Avatar
Did the CEL come on?
James
2000 F350 CCLB 4x4 auto, 250/200's from PIS, No Limit tunes, Isspro gauges, 4" exhaust and intake.
95powersmoker is offline
post #4 of 35 (permalink) Old 04-19-2011, 06:56 PM Thread Starter
to the 1st responce thanks for the help and being a dic*, to 95powersmoke thanks for actually giving me some help, but no the cel didnt come on, no lights or anything on the dash is on or flashing...checked the oil level today and it was good, smelt the oil and it doesnt smell like any electrical is burning... im wandering if maybe its a sensor? but what one...
post #5 of 35 (permalink) Old 04-19-2011, 07:12 PM
OOPS I KILLED A PENGUIN..
Stacks92's Avatar
cam positioning sensor. i had the same problem. no lights just plain no power. sounded like crap when you finally got it started and it died when it got warm. try that
-kenny-
95 OBS 7.3 auto mods: 3in MBRP down pipe, custom intake w/Duralite air filter, shimmed FPR, 4in to 5in dual stacks. Isspro ev gauges in a pillar boost, pyro, trans temp, TS six pos chip, stock, high idle, 40, 60, 75, 140.
Soon to come: DIY electric fuel, built e40D with triple disk tc, rosewood stage two's, Schwitzer s300 turbo.
Stacks92 is offline
post #6 of 35 (permalink) Old 04-19-2011, 07:13 PM
Stacks92's Avatar
p.s. bigrpowr has control....sorry...
-kenny-
Stacks92 is offline
post #7 of 35 (permalink) Old 04-19-2011, 09:14 PM
to the 1st responce thanks for the help and being a dic*, .
He moved it cause you weren't stuck on the side of road, which is what the 911 Roadside Emergencies section is for.
02 f250
countryboyrob is offline
post #8 of 35 (permalink) Old 04-19-2011, 11:48 PM Thread Starter
not arguing cuz im looking for help, but i was stuck in a parking lot. o well, yeah i was thinking the cam sensor.... whats the cost for that guy? and can anybody describe where it is or have a pic of it? thanks for the help stacks
post #9 of 35 (permalink) Old 04-20-2011, 04:54 AM
Stacks92's Avatar
Its on the front of your engine. Easiest way is to lay on the ground and look up. It's right close to the water pump, two or three wires going in to a clip with one bolt holding it on. It's around thirty to forty bucks. Make sure to wet the o ring with oil before instalation I tore the o ring once and was not happy.
-kenny-
Stacks92 is offline
post #10 of 35 (permalink) Old 04-20-2011, 05:18 AM Thread Starter
so i replaced the cam sensor....nothing changed there is what i think to be mist or smoke thats fuel (doesnt smell electrical) from the back of the engine after cranking for a minute or 2....also i noticed a gergling noise from my fuel tank? never herd that before... any chance this could be bad diesel?
what to check/replace now.... thanks again
