pcm question - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 26 (permalink) Old 04-19-2011, 01:01 AM Thread Starter
pcm question
i have a 97 powerstroke 7.3 auto and my pcm is gone bad
the code on it is f7tf-12a650-ta
im in canada andd i cant find one at any wrecker up here
my question is are any other pcm's interchangable
or does somebody in the states have one for me?
fuzzyzuk is offline
post #2 of 26 (permalink) Old 04-19-2011, 01:44 AM
Re: pcm question
I believe the pcm code your looking for is TDE1.
02 f250
countryboyrob is offline
post #3 of 26 (permalink) Old 04-19-2011, 02:11 AM
Re: pcm question
were in canada are you.
2001 F-250 7.3 head studs, pdr super gtp turbo, pdr feed tubes, non ebv pedestal, custom 168cc injectors, boost fooler, dp tuner, manual trany conv, spearco intercooler, pac brake, mbrp 4" exh, afe stg 2, southbend fe clutch, short throw shifter, true-trac limited slip, mag hytec cover, fabtec traction bars, steel cowl hood
camochris is offline
post #4 of 26 (permalink) Old 04-19-2011, 02:18 AM
Re: pcm question
Ideally you are looking for a PCM with TDE1 Code marked on it. It should be on the tag that the above number you noted is on. The TDE1 that Countryboyrob noted has the best shift strategy for the auto tranny for your truck. The other option is to get and any other auto PCM and send it off to a programer and have them re-program it. Or pending what/if you have modifications on your truck you could get a programmed chip from a number of programers. I use Tony Wildman (Total Diesel Performance) for tuning and like what he has done for my truck.
Where are you located? It might be wise as a suggestion for you to go to top left corner of page and click on User CP in there you can fill out your signature and in this way people will see what you have for a vehicle and be better able to assist.
jrc
Tan white tan 97 ECLB, D60 PMF, RSK SD springs front, airs bags rear, 4:10, intake, FFD 205/30s, DP 4 exhaust DIY E-fuel, ZF-5 now
B&W turnover 5th wheel with Anderson hitch.
JCart is online now
post #5 of 26 (permalink) Old 04-19-2011, 02:19 AM
blageurt's Avatar
Re: pcm question
TDE0 and TEE5, TEE4 would also work....What is your code ?
95 E350 Cargo, E4OD , B/M aluminium Pan / 2 HD Trans coolers , Dana 60FF 3:55 , 140 V idm , Autometer guages , TDEO Dp flashed 60 Tow , EBPV delete , BB shim , cat sleeps with the fishes, Timbren SES, stage 1's coming soon
blageurt is offline
post #6 of 26 (permalink) Old 04-19-2011, 02:28 AM Thread Starter
Re: pcm question
im near vancouver bc
fuzzyzuk is offline
post #7 of 26 (permalink) Old 04-19-2011, 03:03 AM
Re: pcm question
Check your PM's
Cheers,
jrc
JCart is online now
post #8 of 26 (permalink) Old 04-19-2011, 04:02 AM
Smart A$$
MN_MountainMan's Avatar
Re: pcm question
I bought mine from the PCM rebuilding company in Florida. Cost about $350 or something.
'97 F-350 CC 5-spd, Pyro, fuel and boost gauges, Banks intercooler, H2E turbo, Adrenaline HPOP, huge clutch, custom ADII regulated fuel system. Should be about 500 hp at the rear, don't know about torque. THIS IS MY BATTLE TANK- Project in Process
4XMayhem.com
MN_MountainMan is offline
post #9 of 26 (permalink) Old 04-19-2011, 04:16 AM Thread Starter
Re: pcm question
so the long number i first posted doesnt have to be the same any tde1 will be fine?
what is the difference between mine and any other auto tranny pcm?
fuzzyzuk is offline
post #10 of 26 (permalink) Old 04-19-2011, 04:55 AM
blageurt's Avatar
Re: pcm question
After 97 they were split shot injectors and the transmission shift strategy is different... any TDE1 or TDE0 or the other ones I mentioned will work....Since there is no 98 model year in the F series after 97 they changed...
blageurt is offline
