Cam shaft lobe for fuel pump - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 04-18-2011, 09:50 PM Thread Starter
smokinstroke97's Avatar
Does the cam shaft on a new body style block have the lobe for a mechanical fuel pump? I am not sure of the year of long block that I got but am not getting any fuel pressure. Pulled the freeze plug and installed a new mechanical pump. It will run on either, so all electrical should be fine I think. The new pump did have the plunger with it so if the lobe is there it should be pumping.
97 F-250 Extended Cab 4x4 Powerstroke, Handshaker, FPR Shim mod, straight pipe.
06 Dodge Dually Quad Cab 4x4 Cummins, Goerend 48re, J and I flatbed, BD Triple Dog, Autometer Trans, Boost, Pyro,
smokinstroke97 is offline
post #2 of 9 (permalink) Old 04-18-2011, 10:19 PM
Re: Cam shaft lobe for fuel pump
99-up (Superduty) motors do not have the fuel pump lobe on the cam.
1994 F-350 4x4 RC 7.3 IDI Turbo, BTS E-4OD, ATS upgrades, BB injectors, Moose Pump, Holley Red.
1997 F-350 CC 4x4 7.3, E-4OD, 6" lift, 38" swampers, 160/80% RDS injectors, TDP tunes.
2001 F-250 RC 4x4 7.3, 4R-100, Straight piped, PHP tune, Western 8.5 MVP.
2003 E-350 7.3, 4R100, 3.55LS. Stock(For now)
t444epsd is offline
post #3 of 9 (permalink) Old 04-18-2011, 11:19 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
What he said... Your going to have to go to an electric fuel system...
Joe
CSIPSD is offline
post #4 of 9 (permalink) Old 04-18-2011, 11:54 PM
dinnerbooter treasurer
genuineford's Avatar
Yeah if there was a freeze plug in there you do not have the lobe for the fuel pump.
93 F350 Gasser
03 F250 6.0
dinnerbooter #3
genuineford is offline
post #5 of 9 (permalink) Old 04-19-2011, 04:42 AM Thread Starter
Man I wished I thought about it when the motor was out. Gonna start orderin parts tomorrow.
post #6 of 9 (permalink) Old 04-19-2011, 04:47 AM
Water under the bridge, I know, but couldn't you generally tell if there's a lobe there by pulling the plug and just looking down there while you turn the motor?
madpogue is offline
post #7 of 9 (permalink) Old 04-19-2011, 05:03 AM Thread Starter
Already have fuel pump installed,didn't even think about it bein different. O well electric will be better anyway
post #8 of 9 (permalink) Old 04-19-2011, 01:59 PM
GoNavy!
DcMoore999's Avatar
I didn't think about it either Electric fuel is better anyways.
I'll send you that stuff tonight Craig.
2000 F-250, RCLB, Auto!!
DcMoore999 is offline
post #9 of 9 (permalink) Old 04-19-2011, 03:36 PM Thread Starter
Will order superduty pump today
