Ticking noise while starting??? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 08-21-2007, 09:02 PM Thread Starter
I have a load ticking noise when I start the truck.Does anyone have any ideas?
Jason Reimer is offline
post #2 of 10 (permalink) Old 08-21-2007, 11:00 PM
Corona Killa
THEDIESELMAN's Avatar
Re: Ticking noise while starting???
When you just turn on the key or while the starter is turning.
2007 DODGE 2500 CREW CAB 4X4 5.9 LITER CUMMINS
2002 FORD F-250 CREW CAB 4X4 POWERSTROKE
THEDIESELMAN is offline
post #3 of 10 (permalink) Old 08-22-2007, 12:58 AM Thread Starter
While the starter is turning.Sounds like something shorting out
post #4 of 10 (permalink) Old 08-22-2007, 03:58 AM
OEM Moderator
Tom S's Avatar
Is it possible you batts are weak and when the starter kicks in the lower voltage is causing a relay to kick in and out? The other one I would probably do is pull the starter and look it over for a start.
Tom
Tom S is offline
post #5 of 10 (permalink) Old 08-22-2007, 04:03 AM
Limp Member
Kanman's Avatar
Loud ticking noise from inside the dash? Your batteries are headed south on ya.
Would be helpful if you could give more than a one sentence explanation of what is wrong. Then we wouldn't have to do the guessing game...
01 F350 CC DRW 4x4 #46
Kanman is offline
post #6 of 10 (permalink) Old 08-22-2007, 04:38 AM Thread Starter
No its under the hood sounds like under truck?
post #7 of 10 (permalink) Old 08-22-2007, 05:46 AM
Check battery terminals for corrosion, and/or being loose.
Check battery cables for damage, corrosion.
Put a batter charger on it, or some jumper cables. If it goes away batteries are fried or you have a bad connection.
gregrob is offline
post #8 of 10 (permalink) Old 08-28-2007, 08:28 PM
Busy Busy
Marty's Avatar
x's 2.
I have to tighten/clean my battery terminals every now and again when it does it and it'll go away after that for a few months.
443.553.9234 - 410.392.3262
Elkton, Maryland
2005 F450 - Tow Bitch
Marty is offline
post #9 of 10 (permalink) Old 09-01-2007, 05:52 PM
<----Colin Banks
mattymx's Avatar
A weird thing happened to my truck last year. it would not start well at all so I changed glow plugs. Still hard to start. I installed new batteries since the original ones were still in the truck. No help there. Then someone told me to look into new battery cables. I siad that mine were fine and there was no corrosion. He said change them anyways and that was the problem. Who would have thought cables could fail and not look corroded....
mattymx is offline
post #10 of 10 (permalink) Old 09-06-2007, 01:06 AM
Busy Busy
Marty's Avatar
When you come over friday I'll show you something that worked for me
Elkton, Maryland
Marty is offline
