95 F250 7.3 Wont Start - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 04-17-2011, 02:16 AM Thread Starter
Truck has been sitting for years. Ran three years ago. Replaced batteries, Changed fuel filter after cleaning out fuel bowl. Cleared drain tube. Replaced Crankshaft position sensor. Tanks have always been full of fuel. I have fuel in the schrader valve on the regulator while cranking. Where do I start troubleshooting? Could the alarm be not allowing it to fire? Thanks.
prerunner007 is offline
post #2 of 13 (permalink) Old 04-17-2011, 02:22 AM
bluedge8's Avatar
Re: 95 F250 7.3 Wont Start
yeah the alarm could be the problem, make sure the tach is moving when cranking and check ALL the fuses. also check the hpop res, it should be 1" below the top full of oil.
1997 f250 4x4 sclb, auto, 3.55's, 191k, diy intake w 6637, ccv mod, pyro, boost, trans gauges, 3" dp to 4" single exh. super chips for now. scangauge
Originally Posted by jdc753 View Post
Besides there is absolutely no way to idiot proof something, since they are always coming out with better idiots by the day
bluedge8 is offline
post #3 of 13 (permalink) Old 04-17-2011, 02:23 AM
95powersmoker's Avatar
Do you get smoke out the tailpipe when cranking?
Does the WTS light come on?
Is the tach moving?
James
2000 F350 CCLB 4x4 auto, 250/200's from PIS, No Limit tunes, Isspro gauges, 4" exhaust and intake.
95powersmoker is offline
post #4 of 13 (permalink) Old 04-17-2011, 02:31 AM
Also, if the fuel is years old, its prolly too low on cetane. i would start with pumping the fuel out of the tanks and replacing it with new along with some stanadyne fuel additive.
It may also help to have the truck plugged in for an hour or so before trying to fire it, depending on the weather in your area.
Another thing you should check, pull the fuel filter housing cap off and have somone crank it over while you watch to see if the fuel filter housing is filling up properly.
Matt07 is offline
post #5 of 13 (permalink) Old 04-17-2011, 04:28 AM Thread Starter
No smoke, Tach is not working. WTS light cycles on and off once like normal.
post #6 of 13 (permalink) Old 04-17-2011, 04:34 AM
What CPS did you put in there? You should be reading about 150 rpms or so when cranking.
James
post #7 of 13 (permalink) Old 04-17-2011, 06:03 PM
bluedge8's Avatar
tach not working is the key, check fuses, you should have a blown fuse
bluedge8 is offline
post #8 of 13 (permalink) Old 04-17-2011, 09:18 PM Thread Starter
Tach does work. HPOP has oil in it. I cant see smoke. I am in the process of removing the aftermarket alarm. Wiring disaster. I dont have the original keyless entry clicker. Hope I dont need it to deactivate the factory anti theft.
post #9 of 13 (permalink) Old 04-17-2011, 09:47 PM
95powersmoker I was wondering how fair should the needle move when cranking? When I crank it just barely moves, but mine starts. After it starts the engine light stays on it idles for a few minutes and just dies. I do it again and it dies then start a third time the light goes out and it runs but idles a little rough. I had put a alternator on yesterday and then another today. Could this be related? Any help would be greatly appreciated. Oh i checked with a snap-on scanner and no codes.
johnpline is offline
post #10 of 13 (permalink) Old 04-17-2011, 09:53 PM
Mine usually gets to about 150-200 when cranking.
As far as your truck dying three times... Next time before you go to start the truck, check your HPOP Reservoir. It should be withing 1/2" of the top.
Anytime the CEL comes on, it should store a code. Maybe need to try a different scanner. What year is your truck?
James
