94 Fell on its face - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 04-16-2011, 03:22 AM Thread Starter
dieselfreek26's Avatar
94 Fell on its face
My boss sold his OBS 7.3 to a kid around town, we constantly see him beating the living sh*t out of it, ripping past the shop, he has virtually no knowledge of diesels, and is always coming in to bug us why its running weird or not running at all, its been in and out of our shop constantly. Heres my question, its been rolling small amounts of blue smoke at idle, which prob leads to injectors, but the other day he had it towed to the shop saying it barrelled out black smoke and fell on its face, it will start but then will stall. any ideas? im clueless with these older engines
08 F350 CCSB, Newton Level, 6000K HID, Custom Harley lights, 4" Turbo back 6" Axle Dump, Spartan 300 LL, S&B, Blocker Plates, MBRP CAC, CCV Mod, BMF Novakanes, Toyo MTs. Future: Suncoast Internals & RCD TC, AirDog II, Batmo Wheels, and No Limit
dieselfreek26 is offline
post #2 of 9 (permalink) Old 04-16-2011, 04:45 PM
blageurt's Avatar
Re: 94 Fell on its face
I would guess fuel pump ... could also be cam sensor or even something as stupid as a fuse....
95 E350 Cargo, E4OD , B/M aluminium Pan / 2 HD Trans coolers , Dana 60FF 3:55 , 140 V idm , Autometer guages , TDEO Dp flashed 60 Tow , EBPV delete , BB shim , cat sleeps with the fishes, Timbren SES, stage 1's coming soon
blageurt is offline
post #3 of 9 (permalink) Old 04-16-2011, 05:10 PM
Daily Stroker
DieselFreak92's Avatar
Nice username
1997
F250 Day Cab Long Bed 4x4 E4OD
- 04 axles - TS chip - diamond eye 5 inch - DIY intake -
- T500 - Stillwell built trans -
DieselFreak92 is offline
post #4 of 9 (permalink) Old 04-16-2011, 07:08 PM
Patrick Feeley's Avatar
My giess would also be fuel pump. See if you can check the pressure while cranking and if it runs, at WOT. Another thing you might try is electrically disconnecting the MAP sensor and see how it runs on the default table values. Cheers!
Patrick Feeley is offline
post #5 of 9 (permalink) Old 04-16-2011, 11:43 PM Thread Starter
Fuel pump is a possibility, i have to check that, it has a new cam position sensor and all of the fuses are good along with the hours i spent tracing wires. Could a tip have broken off an injector? is that a possibility with these older models?
post #6 of 9 (permalink) Old 04-16-2011, 11:44 PM Thread Starter
Originally Posted by DieselFreak92 View Post
Nice username
thanks, you too. haha
post #7 of 9 (permalink) Old 04-17-2011, 02:53 AM
I helped make ur rimz....
MadMax'97PSD's Avatar
does it have a replacement black CPS from international, or a grey replacement one from ford?
'95 F-350 Crew Cab Dually 7.3L. 187k miles - 6637, bitchin aftermarket headlights
'97 F-250 extended cab 7.3L 216k miles-6637, 4in straightpipe
'99 Dodge 2500 Laramie SLT 5.9L 222k miles- flex pipe exhaust, fatal 53 block- fml.
'92 F-350 CCLB 4x4 7.3IDI
Diesel- Fuel 4 Life
MadMax'97PSD is offline
post #8 of 9 (permalink) Old 04-17-2011, 07:07 PM Thread Starter
Im not exactly sure, i asked the boss yesterday, and he said it was replaced, i know he always told me its an international engine...
post #9 of 9 (permalink) Old 04-19-2011, 09:34 PM Thread Starter
So after a lil testing, i see that it keeps blowing a certain 40amp fuse, now i just forgot what is was for but its a 1994 1/2 i believe, took it for a spin and drives normal, minus the light haze from the stack. IDK what happened, or how it fixed itself but im to the point where i should tell the kid to just sell it and get something newer.
