Problem Installing Track Bar Ball Joint - It wants to go in at an angle - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 09-20-2019, 04:25 PM Thread Starter
I got the old one removed from a 2012 F-350 4x4 with no real issues, I just cut the threads like I read on here that others have done and it pressed right out.
I am trying to install the replacement and every time it wants to go in at a bit of an angle. I tried to tap it in a little with a hammer and it doesn't really even want to start. I put the slamp on with everything straight but once I start pressing it in it begins to go at an angle. I cut the threaded bar on the ball joint press in half so I can fit it under the frame rail.
I put it in the freezer for the day and I am hoping that someone may have a tip for me on how to get this thing in straight.
The reinstall portion has by far been the toughest part of this job!
drewkeen is offline
post #2 of 2 (permalink) Old 09-20-2019, 10:19 PM
don't play well w others
Dustybumpers's Avatar
Re: Problem Installing Track Bar Ball Joint - It wants to go in at an angle
This is 09, should be same from 05-13
Charlie
"A common mistake people make when trying to design something completely fool proof, is to underestimate the ingenuity of a complete fool."
Dustybumpers is offline
