2013 superduty psd no crank - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 08-19-2019, 04:33 PM Thread Starter
Hi all,
I have a 2013 superduty that I was adding a couple add a fuses under the hood to power a digital gauge I was installing. Ever since I plugged in the first add a fuse the truck is showing some errors in the message center. It says, Service Advancetrac, Trailer brake fault. Also when I turn the key I donít here the fuel pump prime, nor do I see a glow plug light. I have checked all the fuses. My edge monitor cannot communicate with the truck to pull any codes. Seems like the PCM isnít getting power.
Any Ideas?
Thanks in Advance
JD
Jeremyda23 is offline
post #2 of 2 (permalink) Old 10-01-2019, 10:26 PM
Re: 2013 superduty psd no crank
You have an answer in your question. Return all electrical circuits to their stock condition to begin with.
BOBAH71 is offline
