Fluid Leak Under Dash - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 03-11-2019, 06:08 PM Thread Starter
Hey Guys,
I seem to be having some type of fluid leaking from under the driver side dash of my 2012 f250. Its coming from the black hose with the yellow cap on the end.
Anyone have similar issues or know what this could be?
Thanks!
FlowingSpade is offline
post #2 of 6 (permalink) Old 03-11-2019, 07:19 PM
2011 6.7L (Current)
Whiskey Throttle's Avatar
Re: Fluid Leak Under Dash
Originally Posted by FlowingSpade View Post
Hey Guys,
Thanks!
Iím fairly confident thatís gonna be your brake booster. Is your power-steering reservoir low? Or your brake fluid?
Let us know.
~Whiskey
Whiskey Throttle is offline
post #3 of 6 (permalink) Old 03-11-2019, 07:21 PM Thread Starter
Thanks for the reply. I will check the power steering fluid when I get home. As for the brake fluid, I cant imagine it would be low.
post #4 of 6 (permalink) Old 03-11-2019, 07:34 PM
2011 6.7L (Current)
Well, your power steering fluid and your brake fluid run into the same booster together. Seals inside of it can go had, and rupture into the cab. They will the drip down the rod into the truck, sometimes inside the shaft and sometimes out, sounds like in your case it could be an internal leak if your booster, itís whoís guess is itís steering or brakes, my 0.02
~Whiskey
post #5 of 6 (permalink) Old 03-11-2019, 08:19 PM Thread Starter
Thank you! I appreciate the info. Im going to check the fluid level. Hopefully I don't end up needing a new pump.
post #6 of 6 (permalink) Old 03-11-2019, 08:47 PM
2011 6.7L (Current)
Had mine replace almost a year ago with a reman. It was $500 out the door. Best way to swap it if you do it yourself (I didnít due to not wanting to break brake lines accidentally) removing the driver side front wheel and fender lining is the way to go.
~Whiskey
Similar Threads
5R110 issues after fluid change ? Fluid change tricks ? me2 Transmission Related 20 05-25-2014 03:44 PM
CLEAR FLUID LEAK FROM FRONT OF MOTOR..P/S FLUID? SUPERSTROKED 6.4L Power Stroke - Technical Info 15 05-11-2011 05:41 PM
Christine attacked my truck!! DASH FIRE DASH FIRE DASH FIRE NEED HELP! Christine att turbov6bryan 7.3L Power Stroke Technical Info 26 04-01-2010 10:21 PM
DEF (Diesel Exhaust Fluid) another fluid to maintain White Buffalo Fluids Discussion 3 02-27-2010 10:33 PM
