2011 6.7 blowby/oil leaks - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 02-22-2019, 03:59 AM Thread Starter
Danmendonca7's Avatar
Hey guys I have a later model 2011 6.7 with 133k miles and it has been stock all it’s life. A few months ago I had it tuned with a H&s and deleted everything. Did good for a couple weeks then i noticed fuel mileage got worse, it also developed more engine noise then it used to have, almost like a slight knock so out of curiosity I checked for blow by and all the sudden it’s got a lot. It does throw intermittent cylinder contribution codes from time to time, I think every cylinder has thrown once or twice. Truck runs great outside of the oil leak, crappy mpgs and the occasional white smoke from the exhaust... but im not losing coolant from what I see. I’ve heard all kinds of horror stories about these 2011s so if anyone has had this issue or knows what causes this issue please throw in your two cents Thanks
Danmendonca7 is offline
post #2 of 7 (permalink) Old 02-22-2019, 08:40 PM
sooty
Re: 2011 6.7 blowby/oil leaks
All six sevens have excessive blow by. Check the CCV filter and make sure it isn't plugged. My bet is your injectors are getting tired
sooty is offline
post #3 of 7 (permalink) Old 02-23-2019, 11:38 PM Thread Starter
Thanks for the reply, it seems pretty bad to me. I’ll paste a link to a video of it below, just trying to get an idea of what I’m in for before I take it to a shop 2 hours from me. Watch “Ford 6.7 blow by” on Vimeo: https://vimeo.com/319240361?ref=em-share
post #4 of 7 (permalink) Old 02-26-2019, 12:27 AM Thread Starter
Ended up being a faulty injector thanks
post #5 of 7 (permalink) Old 02-26-2019, 12:09 PM
sooty
Called it!
sooty is offline
post #6 of 7 (permalink) Old 02-26-2019, 12:24 PM
HilhavenFarm's Avatar
Originally Posted by sooty View Post
Called it!
1996 F350 XL Crew Cab LB 4x4 3:55
Former Ft. Bragg/Pope AFB Truck
DieselSite Coolant Filter
Riff Raff Diesel Turbo & Y Boot Kit
Riff Raff Diesel HPX
Mile Marker 449SS Manual Hubs
1987 F250 XLT Lariat LB 2WD 4:10
6.9/7.3 IDI Swap-SOLD
2010 John Deere 5055D
1974 Deutz 5506
2950 hours-"The Tank"
HilhavenFarm is offline
post #7 of 7 (permalink) Old 03-24-2019, 02:01 AM
How much did it run you to get the injector replaced
Guatavo1017 is offline
Similar Threads
Is this too much turbo oil blowby ? (pictures) adamkur 1994-1997 Power Stroke Technical Info 5 07-02-2015 12:03 AM
leaks leaks leaks Powerstrokin444 6.9 - 7.3L IDI Diesels 83-93 Model Years 5 05-28-2009 12:26 PM
damn oil leaks!!! JAKE 1994-1997 Power Stroke Technical Info 5 02-26-2008 10:52 PM
Oil Leaks Reubine 1994-1997 Power Stroke Technical Info 15 02-19-2008 09:49 PM
Oil (leaks) on a 01 F350 Cat_Rebel 7.3L Power Stroke Technical Info 6 09-13-2007 01:02 AM
