low fuel pressure - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 08-03-2016, 12:34 AM Thread Starter
low fuel pressure
this is my 1st post and hopefully someone can help me. I have had many ford diesels over the years with almost no problems. I am currently having a problem with a 2014, 6.7, f-550. About 8 months(12k miles) ago the fuel pump went in the truck and was replaced by the dealer. A week ago the low fuel pressure warning appeared again so i brought it back to the dealer. They put the truck on the scanner and looked at the fuel filter, the primary was full of black debris. I was told that the tank was becoming delaminated and should be replaced, but the tanks were on backorder, and was not under warranty. I told them to put the filter back and i would replace the filter and tank. I immediately changed the filters, which seemed to fix it for about 5 miles, then the 'low fuel presure' warning came on. I then got a Titan tank and changed it, then changed the filter again and erased the codes. It was fine at idle for 10 minutes and for about 2 miles, then the same thing. I haved checked for leaks, made sure the filter was tight and even changed it again. Everytime the filter was changed I cycled the fuel 8 times and the truck started right up. Hoping for some help.
keggy1970 is offline
post #2 of 4 (permalink) Old 08-03-2016, 03:02 AM
codykthekilla's Avatar
Garage
Re: low fuel pressure
Check the pump inlets for debris, it could be stopped up or pump might be damaged due to debris.
2002 F-250 CCSB PSD 4X4, 38R, S&B CAI, Bully Dog GT, 4" Exhaust, 05 head lights and grill, 08 power fold mirrors, tailgate, bumper, tail lights, 2014 chrome steps.
1979 Bronco 4X4, 460, c6, 205
2003 Ranger 2.3 MT 2wd
codykthekilla is offline
post #3 of 4 (permalink) Old 08-22-2016, 10:56 PM
Fummins90's Avatar
I second that. Do you use any fuEl additives? I've seen the paper caps fall into the tank and end up on the fuel pickup. Any DTCs?
Fummins90 is offline
post #4 of 4 (permalink) Old 04-17-2019, 04:03 AM
Flush or replace the fuel lines
Jetzel88 is offline
