Power Mirror not Folding - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 07-11-2014, 11:59 AM Thread Starter
The drivers side mirror on my 2011 King Ranch has stopped folding in. The passenger side still works fine. The drivers side folds in a little and screeches as it tries to fold in. Does anyone have info as to how to take the mirror apart to get to the internal motors and gears?
CJinPA is offline
post #2 of 10 (permalink) Old 07-11-2014, 05:15 PM
14SilverPlatinum's Avatar
Re: Power Mirror not Folding
I have heard it is not a serviceable repair. Basically you junk the entire mirror and replace it.
2014 F250 SUPER DUTY Platinum Edition
Rough Country Leveling Kit, Fuel Maverick Black Milled 20x9 zero offset w/ Nitto Trail Grapplers 35x12.5x20
Spyder Smoke Halo Headlights, Recon Smoke Tail lights and Mirror Side Marker Lights,
14SilverPlatinum is offline
post #3 of 10 (permalink) Old 07-11-2014, 06:34 PM Thread Starter
At around $1000 per mirror I'm not junking it. I will continue to fold it in manually.
CJinPA is offline
post #4 of 10 (permalink) Old 07-24-2014, 09:45 PM
I had the same issue.
Dealer covered it under warranty.
2012 6.7 CCSB V-Red (stock for now)
Clomax is offline
post #5 of 10 (permalink) Old 08-01-2014, 04:03 AM
I took the mirror apart on my wife's Tahoe, for the same issue, and it looked like you could probably swap it out, but I was told by the stealership that you can't replace just the motor. She broke the damn glass in it too, so I just bought a whole new mirror.
jimspenz is offline
post #6 of 10 (permalink) Old 08-03-2014, 05:22 AM
I tried with my mirror as well. Save the headache and replace the whole mirror. You must take the glass out and it will become loose after removing it.
konrad is offline
post #7 of 10 (permalink) Old 09-01-2014, 12:08 PM
My mirrors stopped folding and adjusting.took it to the dealer and they found a faulty wire causing the problem. Second faulty wire I've had, first time was the airbag sensor wire causing the light to stay on in the cluster. Only in this day and age do wires go bad after a couple years
Colton 45 is offline
post #8 of 10 (permalink) Old 09-11-2014, 07:10 PM
Wiring problem with me also. Same fault was not letting power to the map lights. Fixed, but now I have no telescope on the driver's side.
mreynajr is offline
post #9 of 10 (permalink) Old Today, 01:25 PM
a2t
You can buy upgraded replacement motors and metal gears for the ford mirrors now so you dont have to junk expensive mirrors just because the fold or telescope feature fails.
Look here on gruvenparts website in the Ford section.
Hope that helps you save a paycheck or 2 in this.
a2t is offline
post #10 of 10 (permalink) Old Today, 04:47 PM
You have resurrected a thread the is over 5 years since last response.
Hopefully by now he has solved the problem?
Larry
2015 F350 Ultra Lariat 6.7L CCLB DRW 3.73 Limited Slip, Green Gem Metallic w/ Caribou accent, Camper Package, Titan 65gal tank, Rapid Heat, Block Heater, Upfitter Switches, Dual Alternators, Camper Package, Cable Lock, Husky Floor Liners, Spray in Bedliner, 5th Wheel Prep, 25K 5th Wheel Hitch, Ford Goose Neck Hitch.
Larrgh is offline
