Cargo lights - PowerStrokeNation : Ford Powerstroke Diesel Forum
 1Likes
post #1 of 15 (permalink) Old 10-06-2016, 07:04 PM Thread Starter
Trust me, I got this...
Cummins Junkie's Avatar
Garage
Cargo lights
So, I purchased some nice looking flood lights to fit onto my headache rack I got recently. I must confess I don't have a clue what I need and I can't find many helpful answers to my specific scenario, so I figured I would ask around and see what I need in ways of supplies and whatnot. The wire that came connected to the lights (two lights I should say), was 18 gauge. I already have a 20 amp switch and a 20 amp in-line fuse. Anything else I need to try and connect it to the battery? Is the switch/fuse gonna cut it? Thanks guys.
PS, anyone got any ideas on how to secure the wiring to my headache rack that's out of sight and unnoticeable?
Shoulda bought a Cummins.
1997 F250 7.3L XLT, 4x4, 5spd, 315K, TS chip, BD Turbo-Thruster II, Donaldson 6637 filter, 4" straight piped dual exit SOLD
1995 F350 CCLB 6.0L WIP
Pain is inevitable. Suffering is optional.
Cummins Junkie is offline
post #2 of 15 (permalink) Old 10-06-2016, 09:23 PM
79jasper's Avatar
Re: Cargo lights
Northern tool has a harness available.
http://m.northerntool.com/products/s...?hotline=false
I picked it up in store.
Also bought these. http://m.northerntool.com/products/s...?hotline=false But they were out of stock in store, which they were having a sell on. $24.99 so I had to order in store, and they honored the sell price.
If the headache rack is hollow, I would run the wires inside. Use a little grommet to keep the wire from chaffing.
Sent from my SAMSUNG-SM-G935A using Tapatalk
Wood's Powerstroke likes this.
79jasper is offline
post #3 of 15 (permalink) Old 10-06-2016, 09:29 PM
Because I can!!!
Thatchevyguy's Avatar
Re: Cargo lights
I don't like those harnesses just because of the ugly switch. So I make my own. Yes you'll be fine to just fuse it and switch it, however it won't be a bad idea to stick a relay in there.
97 F350 cclb
7.3 5spd
95 f350 rclb 7.3
02 f350 ccsb 7.3
Thatchevyguy is offline
post #4 of 15 (permalink) Old 10-06-2016, 10:17 PM
79jasper's Avatar
Re: Cargo lights
Yeah, switch ain't perfect, but it's still cheaper than I could buy the wire, relay, and loom for. Lol
Already have 2 unused toggles already mounted, so may just cut it off and use one of those.
79jasper is offline
post #5 of 15 (permalink) Old 10-07-2016, 04:16 AM Thread Starter
Garage
Re: Cargo lights
Ultra-Tow Universal Light Wiring Harness — 12 Volt | Mounting Accessories Wiring| Northern Tool + Equipment
Also bought these. Ironton Mini LED Worklights — 2-Pk., 15 Watt, 1,050 Lumens, 10–30 Volt | LED Automotive Work Lights| Northern Tool + Equipment But they were out of stock in store, which they were having a sell on. $24.99 so I had to order in store, and they honored the sell price.
Never considered running them inside, but thats not a bad idea. Thanks for the harness, might have to buy that when I melt something
post #6 of 15 (permalink) Old 10-07-2016, 03:59 PM
410customs's Avatar
Re: Cargo lights
for halogen lights like that (what are they 35 watts? A pair of them it 70watts? you really need to run a relay
The switch turns on the relay, the relay supplies the power from the battery to the lights.
If they were 5watts each or LED's then maybe just the switch will work, anything more should have a fuse and 25amp automotive 4 or 5 prong relay
2001 Excursion 7.3, auto, 4x4, 3.73, collecting parts for suspension lift
2000 E350 7.3, auto 2wd, 3.73, toy hauler camper conversion...researching 4x conversion
21.9 liter family
410customs is offline
post #7 of 15 (permalink) Old 10-08-2016, 12:48 AM Thread Starter
Garage
Re: Cargo lights
Gotcha. I just remembered that the two lights each only came with one wire leading out of them. There should be two right?
post #8 of 15 (permalink) Old 10-08-2016, 03:23 AM
79jasper's Avatar
Re: Cargo lights
Should be, unless they ground through the mount.
Have a link to the light?
79jasper is offline
post #9 of 15 (permalink) Old 10-08-2016, 04:11 AM
Because I can!!!
Re: Cargo lights
There most likely a ground to the mount then.
97 F350 cclb
7.3 5spd
95 f350 rclb 7.3
02 f350 ccsb 7.3
post #10 of 15 (permalink) Old 10-08-2016, 08:07 PM Thread Starter
Garage
Re: Cargo lights
Yea I got them off of ebay
2 Par 36 4 1 2" Round Rubber Housing Work Lights 12V 35W 4411 SEALED Beam Lamps | eBay
