Programming key fob? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 12-31-2009, 06:10 PM Thread Starter
blink182house's Avatar
Whats the steps to program a key fob on a 96 f250 slt? i have power everything, just picked up a fob and the instructions I have read this:
"1. Turn ignition to RUN or ACC.
2. Momentarily jump pins in programming connector located at the base of the steering
column. All doors will lock then unlock to confirm programming mode.
3. Press any button on first keyless remote. Door locks will cycle to confirm programming.
4. If programming a second keyless remote, press any button on second keyless remote.
5. Turn igniton to OFF. Locks will again cycle to indicate end of programming mode."
But step 2, I don't see where the connector is at steering column base to jump.
-Scott ::
blink182house is offline
post #2 of 2 (permalink) Old 12-31-2009, 06:19 PM
Powerstroked
freddie's Avatar
Re: Programming key fob?
Stupid question: You're sure that the truck was equipped with keyless entry? Just because you have power options does not mean you have keyless entry.
Check this thread out first, as it describes how to tell if the truck is even equipped with keyless. I think the description of the location of the keyless module (if you have one) might help you locate those pins
https://powerstrokenation.com/forums/showthread.php?t=47092
97 F250 CCSB
freddie is offline
