hids headlights and foglights - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 12-26-2009, 07:26 PM Thread Starter
smokinstroke's Avatar
got my hids hooked up last night headlights come on ok,but foglights came on and went off right away,prob a blown fuse but my truck did not come with a owners manual so i dont know what fuse to check,also they say to disconnect the daytime running lights not sure what fuse that is either,any help would be appreciated
04 f-350 sct x2, 3in lift w/35in toyo m/t and 20x12 weld dune 8, recon cab lights, straight piped, FCDP egr delete,06 front end and 08 tailgate
smokinstroke is offline
post #2 of 3 (permalink) Old 12-27-2009, 08:30 PM
04MT's Avatar
Re: hids headlights and foglights
I'm not sure on the fuse for the fog light's but I know that there is no fuse for the DRL's. You need to unplug them to disable them. The resistor is located in front of the battery on the drivers side under the perforated shield on the core support in this pic. Just disconnect the wire and your set.
04 F-350 4X4 6.0 Auto,XCAL 3 with Gearhead tunes, ARP's, IPR GEN 2 delete, 58 volt FICM from Swamps, Performance Machine coolant filter with ELC, Blue spring mod, and a Scangauge 2 to watch everything.
04MT is offline
post #3 of 3 (permalink) Old 12-29-2009, 01:39 AM
My 2000 had a fuse for the DRL's. One of the first things i did when i got the truck was pull that fuse. I hate not being able to turn off the lights. Don't know if that changed in the later years or not though. Best way to find a blown fuse is with a test light. Just check for power on both ends of the fuse.
2000 F-350 ccsb 4x4: DIY intake, 4 inch straight, Tuning by [email protected]
99 tacoma V6 5sp 4x4: Chaos/DR mid travel kit, F/R glass, 33x12.50 MTR's---Sold
08 F-150 Lariat Screw 4x4:---Sold
2005 F-250 Lariat ccsb 4x4 auto: All stock for now
Stroke00 is offline
