Firewall Routing - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 12-24-2009, 09:50 PM Thread Starter
Trailer Puller
mentalite's Avatar
Firewall Routing
I need to finally get around to installing the EGT probe that Adam at First Coast sold me. A search comes up with plenty of threads about where to drill the manifold, but information is slim on where to come through the firewall.
I see a couple promising locations. One is only about 8" away from where I'll tap the manifold - it's on the floor behind the gas pedal and looks like the shift cable runs through it now and there is plenty of room to run something else through. The other is on the other side right under where two large bundles of wires run through now - there's a grommet there with nothing going through it. Some insulation would have to be cut away to use this one.
So where do you come through for this and any other wires that you need to run?
Thanks.
'11 F350 CC LB 4x4
mentalite is offline
post #2 of 11 (permalink) Old 12-24-2009, 11:00 PM
Steamfighter
Steamfighter's Avatar
Re: Firewall Routing
Ran mine through the grommet for the e-brake cable. my probe has a braided lead , so not too worried about chaffing . Just notch it with a razor knife and it seals back up good .
2006 F350 6 wheeler. some mods done thanks to First Coast Diesel Performance , but more to come!! .
Steamfitter local 602 Washington D.C.
2005 F250 OVERLOADED WORK HOSS
Steamfighter is offline
post #3 of 11 (permalink) Old 12-25-2009, 02:21 AM
Proud Sponsor
Abrannan19's Avatar
any of those rubber grommets on the firewall can be used. As Brian said above,just make a small X with a knife and route the wire through..
Adam Brannan
Email
Phone (904)-813-5067
2011 F350 KR SWB CC 4x4 tuned by Ford
Abrannan19 is offline
post #4 of 11 (permalink) Old 12-25-2009, 08:05 PM
Captain Negativity!
PSDPlayer's Avatar
Send a message via AIM to PSDPlayer
Is it a probe the uses 2 wires that bolt together? If so, and you aren't using any of the 4 wires (Red, Blue, White, Black) in the harness that already pass through you could use those and not add anymore holes through the firewall.
Email:
Phone:954-275-6801 Leave me a message. I can't always answer.
05 CC LB DRW Lariat 4x2 Dropped 3/6.
PSDPlayer is offline
post #5 of 11 (permalink) Old 12-25-2009, 08:39 PM
Proud Sponsor
Abrannan19's Avatar
The insight probe does not use the two bolt deal like the edge juice.
Adam Brannan
Email
post #6 of 11 (permalink) Old 12-25-2009, 08:41 PM
Captain Negativity!
PSDPlayer's Avatar
ISSpro uses the split wire as well.
Email:
post #7 of 11 (permalink) Old 12-25-2009, 08:44 PM
Steamfighter
The Edge probe has a long section that has a braided stainless jacket . No splices , plugs directly to the Insight harness.
post #8 of 11 (permalink) Old 12-25-2009, 08:48 PM
Captain Negativity!
PSDPlayer's Avatar
The Autometers will use both types depending on the model of the gauge. I need to replace my probe for my Phantom II. It decided to give up when I was racing a newer chevy GTO on the highway.
Email:
post #9 of 11 (permalink) Old 12-25-2009, 08:51 PM
Proud Sponsor
Abrannan19's Avatar
Its been giving up for a few years now...
Adam Brannan
Email
post #10 of 11 (permalink) Old 12-25-2009, 08:59 PM
Captain Negativity!
PSDPlayer's Avatar
It's more important to watch the road in front of you at 130 than look at the temp.
Email:
