Glowshift gauges?? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 12-19-2009, 11:35 PM Thread Starter
ANIMOSITY's Avatar
Glowshift gauges??
have a 3 guage pillar in my OBS,with the GS guages. Is there a way to ste the guages on color, that way I dont have to change them everytime I start my truck? I didnt get get any paperwork with these. Thanks
For those who fought for it, Freedom has a taste the protected will never know!
ANIMOSITY is offline
post #2 of 12 (permalink) Old 12-19-2009, 11:37 PM
Re: Glowshift gauges??
I run them and they stay the color I leave them when I shut my truck off.
Anthony
2000 F-250 205k Few goodies
avancamp1 is offline
post #3 of 12 (permalink) Old 12-19-2009, 11:50 PM Thread Starter
ANIMOSITY's Avatar
I set mine to green and when I go to start my truck again, it goes back to Blue, everytime.
post #4 of 12 (permalink) Old 12-19-2009, 11:59 PM
Thats weird. Well every great once in a while mine will do that but only if I unplug the batteries or let the truck sit for a loooong time.
Anthony
post #5 of 12 (permalink) Old 12-20-2009, 12:07 AM
Metal - It kicks your ass
I've had my guages come back on once with the colors that i've left them. All other times when i start my truck they come on blue. I don't know why. I triple checked my wiring before final installation.
Modded L99
dirtboy25 is offline
post #6 of 12 (permalink) Old 12-20-2009, 12:14 AM
co04cobra's Avatar
Sounds like you need to switch your wires around I cant rem. what colors they are but sounds like you might have the 12v constant and the switched 12v. switched around. Thats what I would try first.
co04cobra is offline
post #7 of 12 (permalink) Old 12-20-2009, 02:36 AM Thread Starter
ANIMOSITY's Avatar
Did that, and the lights were on all the time, even with the truck off.
post #8 of 12 (permalink) Old 12-20-2009, 02:44 AM
Sponsor
DppPower's Avatar
Ok guys I get calls all the time from customers having the same issue. This is an easy fix.
You have to hook all the yellow wires to a CONSTANT 12V source that DOES NOT go on and off with the switch. This is your color memory wire.
If this does not fix your issue then you have to have something else wired wrong. I install a ton of these gauges and have had this happen to me a couple times and it has always been my fault from getting in a hurry.
2008 F450 CC 4x4 King Ranch - Deleted and Tuned
2001 Ram 2500 Ext. Cab - P-Pump 24V Pulling Truck
1999 F250 7.3L Pulling Truck - Top Secret Mods
2003 2500 Freightliner Sprinter- 2011 Polaris Ranger Diesel 4x4
DppPower is offline
post #9 of 12 (permalink) Old 12-20-2009, 02:47 AM
My lights are always on, on mine when the key is turned on. I think thats the only way these can be wired up.
Anthony
post #10 of 12 (permalink) Old 12-20-2009, 02:56 AM
Sponsor
DppPower's Avatar
Yes you are correct...
They have a memory wire and a trigger wire that makes the light come on with the ignition. The gauges that have electrical motors also come on with the trigger wire. So you cannot put them on a seperate switch just for the lights or your electrical gauges will not work properly until that switch is turned on.
DppPower is offline
