Electrical question... - PowerStrokeNation : Ford Powerstroke Diesel Forum
 1Likes
post #1 of 13 (permalink) Old 02-24-2016, 05:13 PM Thread Starter
MorinAidan's Avatar
Hey- I have a backup camera on my rear license plate, but when using it at night the license plate lights blind the camera and I can't see anything. I have some rear facing led flood lights under the bumper off an aux switch and I'd like to wire something up so that when the flood lights are on the license plate lights turn off. What's the best way of going about doing that? Thanks.
2008 F350 CC/SB Bulletproofed 6.4L
Fully deleted w/ Tachyon+
RC 6" lift on 41" 335/80r20 XZLs
MorinAidan is offline
post #2 of 13 (permalink) Old 02-24-2016, 07:09 PM
Moderator
Sbluke55's Avatar
Re: Electrical question...
Add a relay would be the easiest.
You going to have to cut the power wire to your license plate lights.
Hook the power wire for the license plate to 30
Hook the license plate lights to 87a
Tap the power wire from your flood lights and hook it to 86
Then ground 85.
87 is not used
Use heat shrink on all connections. No fuses needed.
MorinAidan likes this.
01 f-250, Standard
Sbluke55 is online now
post #3 of 13 (permalink) Old 02-24-2016, 08:19 PM Thread Starter
MorinAidan's Avatar
Awesome, I'll give that a shot. Thank you!
post #4 of 13 (permalink) Old 02-24-2016, 08:55 PM
Moderator
Sbluke55's Avatar
Thinking about it. Swap 30 and 87a
01 f-250, Standard
post #5 of 13 (permalink) Old 02-24-2016, 09:49 PM Thread Starter
MorinAidan's Avatar
Ok. Thank you
post #6 of 13 (permalink) Old 02-24-2016, 11:34 PM
Luddite in Charge
Mr_Andy's Avatar
Difference being less energized conductor within the relay?
Mr_Andy is offline
post #7 of 13 (permalink) Old 02-25-2016, 01:49 AM
Moderator
Sbluke55's Avatar
Yeah. No need to energize post 87 when the floods are on. With the power wire going into 87a and the floods turned on. Power stops at 87a.
01 f-250, Standard
post #8 of 13 (permalink) Old 02-25-2016, 08:43 AM
Luddite in Charge
Mr_Andy's Avatar
Should probably specify that OP wants a 'normally closed' single pole relay for when he goes to buy...
Mr_Andy is offline
post #9 of 13 (permalink) Old 02-25-2016, 10:42 AM Thread Starter
MorinAidan's Avatar
I assumed it would be a normally closed one I'm looking for. Does it need to be a 5 leg?
post #10 of 13 (permalink) Old 02-25-2016, 12:41 PM
Moderator
Sbluke55's Avatar
It doesn't have to be a 5 leg.
This is what I found off of a quick search. It's a 5 leg though.
http://www.qualitymobilevideo.com/50...yKAaApg68P8HAQ
01 f-250, Standard
