aftermarket power distribution (relays) - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 22 (permalink) Old 12-15-2009, 12:50 AM Thread Starter
I have a bunch of things that need to be wired up shortly, and they all need relays. 2 a/w ic pumps, 1 fuel pump, and 2 water injection pumps. I can get them all wired up, but, there has to be an easier, neater way. I am looking for something that I can run one big 12v+ to and do the wiring from there. Anybody know of anything? I searched around at some audio stuff, but didn't see what I am looking for.
03 E-350 7.3, forged rods, exhaust ported heads, comp 910's, 38R/47, 4.10LS, stealth twin pumps, 300cc hybrids from Swamps, h-11's, racerx trans and TC, Swamps tunes, water...
rpm-inc is offline
post #2 of 22 (permalink) Old 12-15-2009, 12:55 AM
Don't EFN worry about it
Aljay's Avatar
Re: aftermarket power distribution (relays)
Go to a bone yard and get one out of a ford crown vic police car. might even look at the f-150 deal mounted on the firewall pass side.
Tuned by T Wildman
Aljay is offline
post #3 of 22 (permalink) Old 12-15-2009, 01:00 AM
ARMY bound
ahhh if you need the police junction boxes I'll see if I have any around. I usually pull them out with the police wiring and toss them. But I might be able to find some if you want. PM me if that's what you end up needing.
bbbxcursion is offline
post #4 of 22 (permalink) Old 12-15-2009, 01:06 AM
Caption This
444-4D's Avatar
Do you like these?
http://www.autotrendefi.com/images/P...fusepanel2.jpg
If only those who knew what they were talking about replied, this thread would still be on page one.
2000 F-250 CC 4x4 PSD Auto
444-4D is offline
post #5 of 22 (permalink) Old 12-15-2009, 01:09 AM Thread Starter
Thanks! That may be just what I need. And when you wrote crown vic police car, I thought of bbx.......
I guess I would need to see what one looks like, but I can imagine a police car requiring a lot of relays, and should work fine. When you have time, that would be great! Thanks!
rpm-inc is offline
post #6 of 22 (permalink) Old 12-15-2009, 01:17 AM Thread Starter
Originally Posted by 444-4D View Post
Not much, but I am not picky! Thanks. On another note, I realize that each device requires it's own 12v power. Suggestions on wiring 12v to each device? Directly from battery? How do I run a bunch of 12v wires direct from battery? Of significant size, 10 ga?
rpm-inc is offline
post #7 of 22 (permalink) Old 12-15-2009, 01:25 AM
Caption This
444-4D's Avatar
I'd use a fine strand 8 gauge for the power wire. I'd power all of the relays with the same wire. Then I would install a small short connector from the power terminal to the + side of the relay coil and switch the - side. You might even find a relay that is internally wired.
444-4D is offline
post #8 of 22 (permalink) Old 12-15-2009, 03:03 AM
Village Idiot
southmike's Avatar
you can always run a larger wire to a dist pannel then tap off that.
each can have its own feed, fuse etc. there was a new product in one of the diesel mags not too long ago dealing this very problem , basically it was a small box or series of boxes that distributed power but was suppose to use far less wiring. have a look at some boat shops etc, they have hundreds of different sub pannels, distribution blocks etc.
southmike is offline
post #9 of 22 (permalink) Old 12-15-2009, 03:11 AM
mnstroker's Avatar
Run a power distribution box like they do with amplifiers
Back to stock for now.
Originally Posted by 1800joedaddy View Post
It's one thing to get cornholed... its another to pay for the cornholing!
mnstroker is offline
post #10 of 22 (permalink) Old 12-15-2009, 04:09 AM
ARMY bound
I'll see if I can find some of the police junction boxes for ya, there is usually 2 of them in a car.
