High Idle Mod Problem - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 18 (permalink) Old 12-13-2009, 07:22 AM Thread Starter
Custom Trailer Sales
TrailerHauler's Avatar
Well, I've had the switch mounted up for awhile that says "idle speed" and everything. So today I decided to give it a purpose. I followed this link HERE. The only thing I did different was, substituting the red wire on the IVS for the red wire with a yellow trace, and the green wire on the IVS for a red wire with a green trace, since that's what was on my IVS.
Any ideas why it won't idle up when the switch is on and I play with the POT?
I'm stumped, I'll have to look into it better next weekend but I was hoping someone would have some input in the meantime.
1999.5 F350 PSD CC Dually 05' Conversion
Stage I's - Gearhead Tuning - BTS - PCS
F550 rear suspension
1999.5 F350 PSD S/C 6spd Dually
R.I.P. Will Iott - "This ain't no practice run"
TrailerHauler is offline
post #2 of 18 (permalink) Old 12-13-2009, 01:25 PM
CGMKCM's Avatar
Re: High Idle Mod Problem
I am not trying to start tuner wars part 10, but I have a AIC from Ford that works great with no chip, and with one tuners chip, but not with another s. Try pulling your chip.
[SIGPIC][/SIGPIC]
2001 F-550 4X4 Lariat
BTS Tranny
PHP Phoenix chip
H2E Turbo With WW II
Adrenalin
Banks Intercooler and exhaust
In tank and pre-pump mods
Numerous minor Mods
Other Diesels
08 GL 320 CDI
02 VW Golf TDI
3054 Kioti Tractor
Kubota ZD 323
CGMKCM is offline
post #3 of 18 (permalink) Old 12-13-2009, 05:00 PM Thread Starter
Hmm, I guess that's possible. I've heard the problems people were having with a certain tuner, and thier headlights killing the truck.
Anymore input on the wiring is appreciated.
post #4 of 18 (permalink) Old 12-13-2009, 05:35 PM
HHAUL'N STROKER
SMOK'N BLUE STROKER's Avatar
Not to derail the thread but can our trucks be programed to use the cruise control to set the idle? As the big trucks can use their cruise to set idle for warm ups or pto control.
SMOK'N BLUE STROKER is offline
post #5 of 18 (permalink) Old 12-13-2009, 05:45 PM Thread Starter
Not that I've ever heard, I wished that's how it was. Its such a nice setup, and clean method for high idle. That's how the dodges are when you change some pin on the ECM.
But instead we have the option to purchase a Ford AIC module, or do what I did and try to get it to work.
post #6 of 18 (permalink) Old 12-13-2009, 06:18 PM
Why not get a high idle file on your chip?
1999 F350 6SPD 4x4 LARIAT Tymar, DP-F5, ITP Reg Return, 4" Exhaust **SOLD**
2002 F350 REG CAB DRW 2WD Tymar, PHP, 5" stack, DJM drop hangers and shackles, Hellwig sway bars, Nathan K5LA, Full Power '08 Mirrors...**SOLD**
DIRTBIKEZ is offline
post #7 of 18 (permalink) Old 12-14-2009, 02:22 AM
Village Idiot
southmike's Avatar
I am sure it can that is how the sp ebpv brake works,
They are just switches after all,
but remeber there is an airbag trigger amungst that nest of wires
southmike is offline
post #8 of 18 (permalink) Old 12-14-2009, 02:24 AM Thread Starter
The DP tuner is going bye bye shortly, and I don't want to waste a position on the chip with a high idle position.
post #9 of 18 (permalink) Old 12-14-2009, 02:25 AM
Village Idiot
southmike's Avatar
Also I have an aic and a high idle tune, like the aic battery charge feature, being abkle to set. Diff rpms is nice as well. Chip and aic hold rpms very well, but no parking brake needed for the chip either.
post #10 of 18 (permalink) Old 12-15-2009, 03:15 AM
<<< Power
chvyrkr81's Avatar
Then don't put "stock" on the chip. If I need to see what my truck is doin stock, I pull the chip.
06
02
97
74
chvyrkr81 is offline
