idm mod - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 29 (permalink) Old 12-05-2009, 12:13 AM Thread Starter
CatDieselTech's Avatar
Send a message via MSN to CatDieselTech
idm mod
is it worth the 100 bucks for the icm mod from beans diesel performance??
95 f-250
Diy intake
3" dp to 4" straight pipe
tw tunes
CatDieselTech is offline
post #2 of 29 (permalink) Old 12-05-2009, 12:15 AM
Re: idm mod
Yes
F-350 is offline
post #3 of 29 (permalink) Old 12-05-2009, 12:18 AM
USASF Retired
halo's Avatar
Re: idm mod
What exactly is the benefit of this mod?
1996 F-350 Crewcab 4x4 7.3 PSD E4OD
"The pacifists always lose, because the anti-pacifists kill them." - Raymond S. Kraft
"The true soldier fights not because he hates what is in front of him, but
because he loves what is behind him." -G. K. Chesterton
halo is offline
post #4 of 29 (permalink) Old 12-05-2009, 02:06 AM
Going Crazy
badluck_early99's Avatar
Send a message via MSN to badluck_early99
Re: idm mod
crisper throttle response and a a lil more fuel, as i understand it its bumping the voltage up and allowing the injectors to fire quicker and more accuratly alowing them to flow all the fuel they are supposed to
1999 F250 PS 6spd, 37x12.50x17 ProComp Xmud, 06 Grill & Lights. DP tuner, Terminator Hpops, Garrett 42, Casserly B codes, FASS Fuel system by DI, H11's, ITP Reg Return W/Bowl Delete, Sknab 6oh Intercooler, DIY Intake, 4'' Exhaust, Itp OBA, Autometer boost and pyro, , ccv
-Richard-
badluck_early99 is offline
post #5 of 29 (permalink) Old 12-05-2009, 08:19 PM
Re: idm mod
Actual results vary from truck to truck. Basically it gives, a smoother idle, improved throttle response and a bit more HP and torque (usually noticeable by seat of the pants dyno).
Voltage is increased from stock (allbeit 100, 110 or 120 volts) to 140 volts. What's actually happening is the injectors are opened sooner and held open slightly longer.
'95 F250 Extended Cab E40D 2WD
IDM MOD - HPX -
dzlstroker is offline
post #6 of 29 (permalink) Old 12-05-2009, 10:17 PM
Re: idm mod
it really starts pulling harder at about 1800 rpm and up. Mine was a 100 volt module and I upgraded it to the 140 volt. Should have done this mod a long time ago.
1994.5 F350 CC Dually, 1995 7.3 engine, BDP stage 1 sticks,Banks IC/piping,D66 turbo w/1.15,tymar intake, valair fe clutch,4.10 gear,BDP 6 position flip switch,3" downpipe and 5" exhaust w/cat delete,Stealth SRP1, custom electric fuel and idm mod by o'red, BDP Tunes by Jonathon.
o'red is offline
post #7 of 29 (permalink) Old 12-06-2009, 12:02 AM
'' fukin boosten''
OCstroker's Avatar
Re: idm mod
does any one know wat the diffrence is between the beans idm and the swamps idm since swamps is 175 more
96 f-350 regular cab fummins-sold
05 f-250- arp's, absolute egr delete,bpd ficm with innovative tune,175/stock, diesel sites wicked wheel, blue spring, dozers banjos, s&b Intake, gogo dr solenoid, 5'' ex.
OCstroker is offline
post #8 of 29 (permalink) Old 12-06-2009, 12:07 AM
Re: idm mod
Swamps HF-HV IDM has tweaked the frequency (HF) as well as increased the voltage (HV).
He's no doubt put a lot of work into this new mod.
IDM MOD - HPX -
post #9 of 29 (permalink) Old 12-06-2009, 12:20 AM
DieselPower1966's Avatar
Send a message via MSN to DieselPower1966
Re: idm mod
how does the IPR (injection pressure regulator) come into play if you change the ICP?
DieselPower1966
John
DieselPower1966 is offline
post #10 of 29 (permalink) Old 12-06-2009, 12:22 AM
Re: idm mod
sorry, maybe it has nothing to do with the IDM can you explain the 3 for me??
DieselPower1966
John
