high idle mod - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 19 (permalink) Old 12-05-2009, 12:02 AM Thread Starter
clutzmi's Avatar
high idle mod
i have a 97 7.3 f250 and winter hit hard here in st. louis it is COLD any the truck ran horrible until i let it warm up and that took for ever. any way i found this and want to know if anyone has done it or something like it for a high idle, and will it work on my truck this one seems to be very easy.
High Idle Mod
thanks in advance
Clutzmi
97 F250 OBS 7.3 Turbo Diesel 4X4, ISPRO gauges (boost, pyro, trans temp), Boost fooler, BB mod, Custom DIY cold air intake, CCV mod, 3" Diamond Eye down pipe, 4" exhaust, no cat, no muffler, Fog Lights, wheels and 285/75/16 tires
clutzmi is offline
post #2 of 19 (permalink) Old 12-05-2009, 12:51 AM
USASF Retired
halo's Avatar
Re: high idle mod
Will this work on a 96?
1996 F-350 Crewcab 4x4 7.3 PSD E4OD
"The pacifists always lose, because the anti-pacifists kill them." - Raymond S. Kraft
"The true soldier fights not because he hates what is in front of him, but
because he loves what is behind him." -G. K. Chesterton
halo is offline
post #3 of 19 (permalink) Old 12-05-2009, 12:53 AM
Super Hauler!
Super_Hauler's Avatar
Re: high idle mod
found the same thing a few years back, says it works on all 7.3's superduty's and obs trucks. Try it let us know if it works. It all makes sence for the wiring
Super_Hauler is offline
post #4 of 19 (permalink) Old 12-05-2009, 12:55 AM
Don't EFN worry about it
Aljay's Avatar
Re: high idle mod
Awesome I know what I will be doing soon thats cool now I dont have to give up a spot on my chip.
Tuned by T Wildman
Aljay is offline
post #5 of 19 (permalink) Old 12-05-2009, 12:56 AM
USASF Retired
halo's Avatar
Re: high idle mod
I think I will give it a try, it has been pretty cold out, I think it would help. I wonder if you can get it to work with the parking brake off to use for winching.
halo is offline
post #6 of 19 (permalink) Old 12-05-2009, 01:18 AM
All Jacked up on Mt Dew!!
Big-Stroke's Avatar
Re: high idle mod
the write up was on a 2003 6.0. Are the same steps needed to do this to a 7.3?
Early 99, 12" lift, 4" straight pipe 6" tip, tymar, Edge Juice w/ attitude, Edge Evolution, DDP injectors, Zoodad mod, CCV mod, crossover line, Return shimed, 38/15.50/18 Toyo MT's 4.56 gears and ARB, Water/Meth injection, Tru speed, 300k on the dial, more mods on the wish list.
Big-Stroke is offline
post #7 of 19 (permalink) Old 12-05-2009, 02:44 AM
Patrick Feeley's Avatar
Re: high idle mod
I don't think its gonna work on the 7.3 (a separate Auxilliary Idle Controller was used on the 7.3 and I've never seen anyone wire a "single-wire" solution like this). You can build your own Idle Control for relatively cheap. It won't be rock-steady when the truck is cold and warming up (RPMs will increase as the friction losses decrease during warmup), but once it's warmed up idle will be fairly steady. I have a crude diagram and writeup for the one I have been using since 2001 or so. PM me your email address if you want me to send it to you. Cheers!
Added in edit: The mod described may work on 1997 (and later 7.3's). The 1997 EVTM does show wire 323 (Power Take-Off Feed, Light Blue with Yellow trace wire) on PCM connector pin 10. My 1996 and earlier EVTMs do not show it. Cheers again!
Last edited by Patrick Feeley; 12-05-2009 at 02:57 AM. Reason: Added comment on 1997 trucks
Patrick Feeley is offline
post #8 of 19 (permalink) Old 12-05-2009, 02:53 AM
Aljay's Avatar
Re: high idle mod
PM sent
Tuned by T Wildman
Aljay is offline
post #9 of 19 (permalink) Old 12-05-2009, 03:34 AM
Re: high idle mod
OK here's another edit to the above (can't edit message past 30 minutes without contacting administrator ... dumb rule BTW): Wire 294 is the instrument illumination feed on the OBS trucks so you'll have to use another "hot in run" wire to tap. Cheers!
post #10 of 19 (permalink) Old 12-09-2009, 03:09 PM
Cratos's Avatar
Re: high idle mod
get a hi idle setting for your chip much cheaper than a Aic
Blue 2012 XLT SCLB 4X4 , 38,550 miles, 3:55's & 18's Camper and Tow packages. Edge insight, Airlift Wireless compressor & Air Bag set-up, Dieslesite filter.
Cratos is offline
