trouble with illumination on gauges - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 20 (permalink) Old 11-21-2009, 05:13 PM Thread Starter
wheres the fat chicks?
PowerstrokeR00's Avatar
im having trouble find a source for illumination with isspro gauges.can anybody help me.pictures would be great
2000 F-350 SD ccsb=185hp
Matt's Tunes=140hp
6637=20hp
2% window tint=25hp
4in straight pipe=50hp
Custom Fuel system w/ sump=50hp
Foil,AIH,EBPV delete=30hp
Wow...I'm making 500hp
Originally Posted by stroke of luck View Post
i started sharting at an early age...
PowerstrokeR00 is offline
post #2 of 20 (permalink) Old 11-21-2009, 05:17 PM
Re: trouble with illumination on gauges
what kind of trouble are you having?
02 f250
countryboyrob is offline
post #3 of 20 (permalink) Old 11-21-2009, 05:34 PM Thread Starter
i cant find a way to light them um when i turn the lights on
Matt's Tunes=140hp
6637=20hp
2% window tint=25hp
post #4 of 20 (permalink) Old 11-21-2009, 05:40 PM
<---- my shop
vader's fury's Avatar
i hooked mine up to the parking light wire coming out of the back of the light switch on the dash not sure now what wire it was but if you use a test light it will be easy to find.
Robert
2003 F-350 CCLB, 7.3, Auto
2000 F-450 Sold.....
vader's fury is offline
post #5 of 20 (permalink) Old 11-21-2009, 05:42 PM
OBNOXIOUS MOTORSPORTS
alterdst8's Avatar
Send a message via Yahoo to alterdst8
clip on a quick connect right on to the back of the brown wire iirc with your wire for your lights to your gauges. Where your lights are pop it out the whole deal (where you switch your lights on and off) with a flat head youll see the wire and it will even control illumination its been awhile but believe thats the right wire.
02 c/c lariat 4x4 DI studs, Rosewood BIG OIL, 76mm/22cm XXXH2Evil, some fuel, C2 gauges, tru trac F/R 4.30 gears, custom shafts, Stallion TC, Fully built Suncoast, mag hytech pan, 5" pipe, 25k gooseneck hidden hitch , 2 motors, STILL on pmrs in one
Mitch in Mayetta Ks my turbo sponsor
OBNOXIOUS DIESEL built build
alterdst8 is offline
post #6 of 20 (permalink) Old 11-21-2009, 06:03 PM Thread Starter
well i tested all the wires going to my light switch and i only found one that reads +12volts when key is forward and like .44 when key is off.should i try this wire or not
Matt's Tunes=140hp
6637=20hp
2% window tint=25hp
post #7 of 20 (permalink) Old 11-21-2009, 06:40 PM
<---- my shop
the wire that you want is hooked up to the dimmer control that way when you dim your dash lights the gauge lights will dim also. when you test the wires turn the dimmer up and down and your test light should dim and get brighter.
Robert
post #8 of 20 (permalink) Old 11-21-2009, 06:42 PM
it's an 02 05 08
turbodiesel_02's Avatar
2002 ext. cab lwb 4x4 7.3
05 front 08 rear conversion
4in lift,forged rod motor,tunes by tsd,bts trans,6.0 transcooler,6 autometers to watch,studs,springs,push rods,238cc hybrids,itp reg return,stealth hpop,tsd custom fuel system and sump,an so on
6.0's pay the bills and 6.4's soon..
turbodiesel_02 is offline
post #9 of 20 (permalink) Old 11-21-2009, 06:56 PM
FREE THINKER
Chip's Avatar
i think it is light blue w/red stripe
1999 7.3, 2wd ,auto
Chip is offline
post #10 of 20 (permalink) Old 11-21-2009, 07:32 PM
alterdst8's Avatar
ill check right right now real quick but its the wire that goes to the dimmer switch.
