upfitter switches - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 11-20-2009, 04:37 AM Thread Starter
matts05f250sd's Avatar
upfitter switches
Hey everyone- I just started to install a set of bright back up lights, I was thinking about putting them on a trailer plug with the reverse pin to activate them. Then a friend said I should check out some upfitter switches. So heres the question, Is the wiring already there or do you need the loom to go with it? My parts guy at the dealership wasn't sure, but he could get the switches for like $30.
matts05f250sd is offline
post #2 of 8 (permalink) Old 11-20-2009, 05:04 AM Thread Starter
Re: upfitter switches
Well went looking through some older posts and I think I found my answer. But post em up if you have any other ideas. thanks again.
post #3 of 8 (permalink) Old 11-20-2009, 05:11 AM
06powerstroke's Avatar
talk to jdc753, I am pretty sure he added uplifter switches to his truck.
2006 F250 CC LB FX4 Lariat
ARP studs, SCT X3 IDP & Gearhead tuned, S&B CAI, straight pipe, FASS 150/180, FCDP solid uppipe, Dieselsite coolant filter
2.5" BTS leveling kit, 35" Xtreme A/T's on XD Hoss 18's, N-Fab prerunner bar w/ 3 9" Hellas
Pioneer double din, JL components, 3 10" Pioneer subs
06powerstroke is offline
post #4 of 8 (permalink) Old 11-20-2009, 01:18 PM
6Leaker
jdc753's Avatar
Send a message via AIM to jdc753
Yup I did. The switches are seperate from the harness. I would recommend getting the kit from Your Premiere Source for Ford Truck Parts and Accessories that has the switches and harness and all. I got mine from the dealer and I think harness alone was almost $80 while the complete kit can be had for $9x or so.
Here is a good writeup on the install that I used when I did mine, http://www.superdutydiesel.com/wiki/...p?articleId=13
Hope this helps ya. Once they are installed you can coonect the power wire for the lights directly to the switch, that's how I had mine.
2005 F350 Crew Cab Long bed
6.0L / Auto 4x4
SCT X3 5" Magnaflow
4" RCD lift, a bunch of stereo gear and a computer
jdc753 is offline
post #5 of 8 (permalink) Old 11-20-2009, 01:35 PM
Stroker67's Avatar
Upfitter switches are the way to go, i have my guages hooked to one, my backup lights to one and a set of PIAA lights up front hooked to them. Great and well orginized!
Stroker67 is offline
post #6 of 8 (permalink) Old 11-20-2009, 06:35 PM Thread Starter
Thanks for the info guys. My wife works for the local Ford dealership so I get a pretty deep discount, and I found the other part# last night. Thanks for the write up link jdc753, I will be sure to check it out.
post #7 of 8 (permalink) Old 11-20-2009, 07:34 PM
6Leaker
jdc753's Avatar
Sounds good. If you have anymore questions with it post em up. Routing the harness was a little tricky but straight forward. For me it was easier to pull the lower dash but I didn't have the acess cubby down low to reach through. They are definetely a must to have
6.0L / Auto 4x4
SCT X3 5" Magnaflow
jdc753 is offline
post #8 of 8 (permalink) Old 11-20-2009, 07:39 PM
the Ford price with discount will beat any price you find online
deffinately one of the best mods i did to my 05
PMRCM#1
slowleak is offline
