08 Tail Lights in 00 Bed - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 08-03-2015, 04:34 PM Thread Starter
badazzharley's Avatar
I've tried doing a search but kind find anything. Will 08 tail lights fit on a 00 bed? What mods are required if any? I've done the 08 tail gate with step and camera conversion but would like to finish off the look with the 08 lights.
badazzharley is offline
post #2 of 5 (permalink) Old 08-03-2015, 04:37 PM
Moderator
Sbluke55's Avatar
Re: 08 Tail Lights in 00 Bed
All is plug and play except the reverse lights. You need new sockets. Either cut the old ones out and solder the new ones in or there is a way to disassemble an old bulb and get it to adapt the new socket.
01 f-250, Standard
Sbluke55 is online now
post #3 of 5 (permalink) Old 08-26-2015, 02:22 PM
Where can you buy the connector to make the 08-15 reverse lights work for a 06
BigRig is offline
post #4 of 5 (permalink) Old 08-26-2015, 03:01 PM
Moderator
Sbluke55's Avatar
Ford has them but they are stupid expensive. Dorman makes some. You have to modify them a little. Give me a little bit and I'll try to round up a part number.
01 f-250, Standard
post #5 of 5 (permalink) Old 08-31-2015, 04:16 PM
Canadian Stroker
doubledoor's Avatar
Go to your local parts store they will have the sockets for the reverse lights cheap. that's all you need.
2002 XLT CC LB 6speed SRW
4"mbrp turbo back
S&B Intake
autometer NV boost,pyro,water temp and oil pressure
WW2,BRV
DP tunes - QI,60E,80E,40T,60T,100,120.
EBPV delete sensor.
blank pedestal and EBPV housing
ATS turbo housing
DI up-pipes.
2007 headlights,2008 taillights,2010 tailgate
17"Atx ledge with Dick Cepek Extreme Country
doubledoor is offline
