High beam headlights quit - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 10-30-2009, 01:49 AM Thread Starter
Stafford's Avatar
my high beams quit low works i have checked fuses ,multi function switch looks fine inside ,bulbs are fine any help would be appriciated Shawn
Stafford is offline
post #2 of 4 (permalink) Old 10-30-2009, 03:09 AM
GoNavy!
DcMoore999's Avatar
Re: High beam headlights quit
Is the high beam light constantly on? Do you have a Haynes or Chiltons book, if you do you should check your multifunction(wiper/turn signal) switch...It tells you the process on how to check it with a meter... I had some what of the same problem, I ended up making a new ground off the pigtail.
2000 F-250, RCLB, Auto!!
DcMoore999 is offline
post #3 of 4 (permalink) Old 10-30-2009, 12:19 PM Thread Starter
Stafford's Avatar
no the low beams work only and parking lights work on high @ low
Stafford is offline
post #4 of 4 (permalink) Old 10-30-2009, 01:03 PM
GoNavy!
DcMoore999's Avatar
Did you change the bulbs? I would check that multifunction switch..It's pretty easy/
