2005 headlight conversion - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 15 (permalink) Old 09-21-2009, 12:39 AM Thread Starter
Super Hauler!
Super_Hauler's Avatar
i am wanting to do the 2005 headlights on my 99 which pigtails will i need for them? iirc 9006?
Super_Hauler is offline
post #2 of 15 (permalink) Old 09-21-2009, 12:42 AM
GoNavy!
DcMoore999's Avatar
Re: 2005 headlight conversion
The 9007s http://www.puredieselpower.com/catal...ls-p-6003.html
2000 F-250, RCLB, Auto!!
DcMoore999 is offline
post #3 of 15 (permalink) Old 09-21-2009, 12:58 AM Thread Starter
Super Hauler!
Thanks!
post #4 of 15 (permalink) Old 09-21-2009, 02:11 AM
xrxmxcx's Avatar
im doing the same this upcoming week, ordering these up aswell!
anyways, has anyone used a plasma cutter to trim the headerpanel? I might give it a try but wondering if it might be a bad idea?
_
I bought another six four.
xrxmxcx is offline
post #5 of 15 (permalink) Old 09-21-2009, 02:44 AM Thread Starter
Super Hauler!
we just used a die grinder with a cut off wheel on it. It was slicker than chit, only took like 5 mins.
post #6 of 15 (permalink) Old 09-21-2009, 02:59 AM
xrxmxcx's Avatar
how much did you have to cut out, anyone have a good template or image?
_
xrxmxcx is offline
post #7 of 15 (permalink) Old 09-21-2009, 03:01 AM
Lovin the Tuna
RedSmokey's Avatar
The part you have to cut for the headlights to fit is fiberglass. I believe truck toyz has a write up on it...
2001 F250
2000 F250
RedSmokey is offline
post #8 of 15 (permalink) Old 09-21-2009, 12:27 PM
JDG's #1 Fan
99F250Smitty's Avatar
Send a message via AIM to 99F250Smitty
Took this from Bama 6 Gun's write up.......
Brian
_____________________________________________
99.5 F250 Extended Cab Short box. 4x4.
99F250Smitty is offline
post #9 of 15 (permalink) Old 09-21-2009, 01:39 PM
Sleep well my brothers
yamt03's Avatar
The headerpanel is fiberglass a plasma won't work. I used a dremel and a bit thats just for fiberglass/composite material and I was done in about an 1 1/2 hours. And I got the harness from GOS Performance.
Early 99 CC DRW AFE, 4" MBRP,Autometer,6.0 trans cooler, ITP, DP Tuner and cupholder upgrade
Former U.S.A. Res. MP & proud of it!
2005 Dodge 4x4 5.9 With some stuff done to it.
"If you voted for Obama in 2008 to prove you're not a racist…you'll have to vote for someone else in 2012 to prove you're not an idiot."
yamt03 is offline
post #10 of 15 (permalink) Old 09-21-2009, 03:40 PM
Peon
jvencius's Avatar
Originally Posted by yamt03 View Post
...I used a dremel and a bit thats just for fiberglass/composite material and I was done in about an 1 1/2 hours. And I got the harness from GOS Performance.
Same here--I destroyed my Dremel in the process (it was on it's last legs anyway) but that 5-pack of Rotozip-branded spiral up-cutting bits I got was worth every single penny. I used all 5 of 'em, so as to not force it and damage stuff trying to use a dull bit, but they worked awesome.
jvencius is offline
